tri power with a bog
i recently put tripower on small block chevy. i used rochester 2 bbl. the idle circuits have been taken out of the front and rear carbs. when i step on the gas it has a bog and when i m am drivng and go to give it a littel gas it has a bog. what could cause this. any help please.
jeff |
Do you have progressive linkage or do all the carbs open at once? If the latter, you have too much port opening. Get a progressive linkage. If you already have that, adjust it for later opening of end carbs.
i do have progressive linkage. and they open kinda late but not real late. the bog is when i first give it gas not so much going down the road. it will do it from time to time when i am going down the road but mostly when i start off.
ok ill try that
thanks for the help |
i messed with teh acclerator pump and all seems ok. there isnt any slop in teh linkage, when i give it gas everything is right there. as far as the timing goes i have messed with that before and it didnt seem to help to much. would one of those advance kits help. make the advance come in eairler. i also forgot that there is a mild cam in the motor. it is suggested at liek 1100 to 5500 rpm range could that have anything to do with it?
| Power! -- No power? -- Power!!!! No Power???! | Fragzem | Engine | 10 | 05-16-2005 01:30 PM |
| what stereo wires under carpet? | bullheimer | Electrical | 19 | 05-06-2005 06:37 PM |
| Power Steering and Power Brakes | blindboarder711 | Suspension - Brakes - Steering | 1 | 02-09-2004 02:54 PM |
| Car Audio Question | Thuggishruggish3000 | Interior | 14 | 12-23-2003 08:48 AM |
| Tri power spam on e bay | DragLinkscc | Hotrodders' Lounge | 0 | 05-10-2002 07:56 AM |
