-   -   Tri Power Help!! (http://www.hotrodders.com/forum/tri-power-help-137484.html)
jgreene6611 04-23-2008 11:19 AM
Tri Power Help!!
I am putting a tri power setup togethger for my 350 SBC. it is all ready to run with the excepetion of no choke. i want to run an electric choke. i have the right housing for one on my center one. Where do i get one? what year car ran one?
jeff
PatM 04-23-2008 11:25 AM
Do you have a photo? What type of carbs are you running? If you are using original type carbs (2GC Rochesters, I think) I don't know that any car ever came equipped with an electric choke on one of these carbs. But there is probably a conversion out there that'll work.
For the folks here to help you, it'd be good to post the type carbs you are using.
Pat
jgreene6611 04-23-2008 12:05 PM
The carbs are rochester 2GC (small base). it has the housing for a carb mounted choke tht gets heat from the manifold. i need a choke that goes in there.
jeff
matt167 04-23-2008 12:43 PM
Part # R-65A from This place
1957plymouthhemi 04-23-2008 08:59 PM
The integrated choke 2G carbs were generally found on the smaller pontiac V8s and V6's. Check with your local parts store and look up something in the mid-late 70's
