Tri Power Help!! - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-23-2008, 11:19 AM
Tri Power Help!!
I am putting a tri power setup togethger for my 350 SBC. it is all ready to run with the excepetion of no choke. i want to run an electric choke. i have the right housing for one on my center one. Where do i get one? what year car ran one?
jeff
Old 04-23-2008, 11:25 AM
Do you have a photo? What type of carbs are you running? If you are using original type carbs (2GC Rochesters, I think) I don't know that any car ever came equipped with an electric choke on one of these carbs. But there is probably a conversion out there that'll work.
For the folks here to help you, it'd be good to post the type carbs you are using.
Pat
Old 04-23-2008, 12:05 PM
The carbs are rochester 2GC (small base). it has the housing for a carb mounted choke tht gets heat from the manifold. i need a choke that goes in there.
jeff
Old 04-23-2008, 12:43 PM
Wiki Edits: 31
Part # R-65A from This place
Old 04-23-2008, 08:59 PM
Last journal entry: A few ongoing projects
The integrated choke 2G carbs were generally found on the smaller pontiac V8s and V6's. Check with your local parts store and look up something in the mid-late 70's
chevy 350 jimang22 Engine 4 07-14-2007 03:49 PM
Power! -- No power? -- Power!!!! No Power???! Fragzem Engine 10 05-16-2005 01:30 PM
Power Steering and Power Brakes blindboarder711 Suspension - Brakes - Steering 1 02-09-2004 02:54 PM
Car Audio Question Thuggishruggish3000 Interior 14 12-23-2003 08:48 AM
Tri power spam on e bay DragLinkscc Hotrodders' Lounge 0 05-10-2002 07:56 AM
