-   -   tri-power help (http://www.hotrodders.com/forum/tri-power-help-94104.html)
caplock 07-19-2006 07:44 PM
tri-power help
I've got a 331 Cad w/ 3 Stromberg 97's w/ 45 mains and and progressive linkage on an Edelbrock manifold. My problem is the back 2 cylinders (#7 & #8) are running HOT, especially #7. The basic functions of the carbs seem to be fine, float, pump etc. Any ideas from you 3 deuce experts?
woodz428 07-20-2006 05:40 AM
I would suspect an air leak. Some flammable contact cleaner sprayed on the manifold/head joint and any other vacuum fittings in the area should pinpoint it.
