tri-power and vacuum brakes??? - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-15-2007, 08:31 PM
i have an offy tri-power manifold with Holley 94's on it for a SBC. Were do i get vacuum for my brake booster?
Old 09-15-2007, 09:27 PM
DoubleVision's Avatar
I`m unsure, but I`m thinking this intake wasn`t made for the use of Vacuum brakes otherwise I`d think there would at least be a provision for it. That`s not to say you couldn`t drill and tap your own or have a machine shop do it. Let the carbs sit on the intake and study the design until you see what will be easiest and look neatest. Good Luck.
Old 09-16-2007, 09:52 PM
where would i drill to hook up a vacuum line?
Old 09-17-2007, 06:59 AM
Shoot for a runner if you can, close to the plenum as possible. I`m sure you could likely place it in the plenum as well. I`ve seen them on the rear of the plenum under the carb in many cases. Just make sure to check it very very closely to make sure it`s not going to cause any interference problems.
Old 09-17-2007, 07:10 AM
Not A T 25's Avatar
Takes Guts To Cut One Up
A much easier method is to add spacer plates under the carbs they are available with the vacuum port and without. This will also improve the low end torque by keeping the fuel cooler and adding velocity to the runner system. They are not cheap but it is much less risky.
Success is getting what you want but happyness is liking what you get.
Old 09-18-2007, 11:16 PM
where would i get such a spacer
Old 09-19-2007, 07:17 AM
Not A T 25's Avatar
You could make them but they are readily available thru swap meets and parts suppliers.
Old 09-19-2007, 03:57 PM
Brakes
If you have power steering you could just switch over to a hydroboost power brake system.
Vacuum advance hooked up directly to manifold....is this bad????? Steve-0321 Engine 69 03-10-2014 05:10 PM
Distributor Tuning and Theory - Part 1 Rick WI Engine 35 04-26-2011 12:38 AM
Port or Full time vacuum cool rockin daddy Engine 129 10-05-2010 03:00 PM
Vacuum adv.. underdog305 Engine 58 01-30-2007 11:19 AM
Ported Vacuum 72Orange Engine 18 08-07-2006 08:56 PM
