Tri star engines 427 sbc - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 01-23-2013, 08:23 PM
hcompton's Avatar
Old & Furious
I used cnc many times they are also much more likely to over speed the bit and trash the work peice and continue to do so until your block and bit are both scrap metal.
The price is right and the motor is the right stuff. Dart tall deck block with pro 1 heads should be in the 500 hp range woth good cam and compression.
Now make that an 18 degree motor and the same 427 is 700 hp and 20k.
If 550 hp is more than you need you should be happy if it lives up to spec. But if you think adding a fogger plate later on is a good plan better think about another rotating assembly for any upgrades. Consider it maxed out and you will be happy.
  #17 (permalink)
Old 01-28-2013, 09:14 PM
Would these 427 small blocks be able to live in front of an m21 Muncie 4 speed? Freshly rebuilt?
  #18 (permalink)
Old 01-28-2013, 09:19 PM
vinniekq2's Avatar
A 427 could spit out that muncie with no troubles at all.You should beef up the muncie
  #19 (permalink)
Old 02-08-2013, 10:58 PM
Hey guys I have a few concerns about this engine was wondering if you guys could help me out. First of all I was concerned about the 4 inch stroke this engine I've heard that it can be problematic it's not the best set up. I have also heard horror stories about 427 small block oil pan fitment something like you can only use every other bolts because of clearance issue is there any issue with this? Also I'm concerned with oil consumption with the 427 small block? Also are there any issues with running one of these darts locks on the street
  #20 (permalink)
Old 02-09-2013, 07:52 AM
milodon makes a nice oil pan that utilizes every bolt and clears the crank/rods.
if proper rings/honing procedures are used, oil consumption should be no higher than any other small block of similar configuration (hot street use, drag race, circle track etc.)
not sure which dart block they are using, but there should be no issue using any quality block from dart, world, etc.
  #21 (permalink)
Old 02-09-2013, 11:28 AM
vinniekq2's Avatar
the 434 in my corvette is 10 years old.
1966 427 ford sohc how many original engines? roysaric Hotrodding Basics 24 10-16-2011 08:42 AM
366 & 427 TD chevy engines m/w Engine 5 03-16-2010 10:03 PM
427 tri carb runs poorly after warmup mackyLS6 Engine 12 12-02-2009 08:45 AM
SBC Tri Power Help jgreene6611 Engine 5 01-14-2008 10:50 AM
my friend's body is a star. a shooting star bullheimer Hotrodders' Lounge 4 08-26-2004 11:31 AM
