Triangulated 4 Bar ??? - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-28-2006, 05:50 PM
I just removed the front clip and rear end out of my 81 Malibu donor car. Im putting all this stuff in a 50 GMC. My question is this rear end ,it's a 10 bolt ,but it has the stock mounts on it that look like a tri 4 bar setup.. How hard would it be to make my own bars and fab this up ? I want to bag it also . Has anyone done this or will it work?? Thanks Jim....
Old 05-28-2006, 09:10 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
lets move this to the suspension section to see the guys there can help you..........
thx
Old 05-29-2006, 06:41 AM
cboy's Avatar
Last journal entry: Finished
Jim,
I believe that would work quite well. If you have the donor car you should still have the trailing arms etc which you can probably use as well (may want new bushings). Here is a shot of a 9" Ford adapted to a Malibu triangulated set up along with air bags. It works well - and uses all stock parts (except for the mounting brackets).
Always learning...and sharing what I've learned.
Now a Sway Bar question.... MM in NM Suspension - Brakes - Steering 5 03-13-2006 11:53 AM
Dual Master Cylinder Brake Pedal with Balance Bar iceman36 Suspension - Brakes - Steering 6 02-24-2006 12:55 PM
Sway Bar Bushings - Distorted? 66GMC Suspension - Brakes - Steering 4 01-30-2006 08:07 AM
65 Belair Sway bar question sabino56 Suspension - Brakes - Steering 11 12-26-2005 08:22 PM
front sway bar mount location fire power Suspension - Brakes - Steering 2 05-17-2003 07:10 AM
