Triangulated 4 bar rear end - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-02-2008, 09:15 AM
I'm just in the process of building my own frame and was wondering if anyone had some pictures of this set up. I have a '27 Model T Sedan that I'm putting a 383 SBC into. I have a kit that I bought from Speedway but I don't think it will be strong enough:
http://www.speedwaymotors.com/p/3396...nsion-Kit.html
I was thinking ladder bars mounted toward the tranny mount or triangulated 4 bar, don't know which would be the best on a street driver, no strip. From what I'm reading I figure the lowers mount to the frame and the uppers go to the trans mount, is this right?? Also is it okay to mount the coilovers like in the picture? I thought I could use the shocks and panhard bar and then fab the rest. Pictures and explanation would be great!!
Thanks,
Sean.
Old 01-02-2008, 10:08 AM
302 Z28's Avatar
This is a shot of the setup on my 34. I would much rather have this than ladder bars.
Vince
Old 01-02-2008, 10:36 AM
I agree with 302 Z28 ...
A Triangulated 4 bar rides better and leaves more room for exhaust also IMHO
This is the one under my 32 3W coupe.
Old 01-02-2008, 11:11 AM
cboy's Avatar
Last journal entry: Finished
Here's another one. This is in my '32 pickup. Basically Chevelle components mounted in an Econoline frame.
Always learning...and sharing what I've learned. The Scratch-Built Hot Rod.
Old 01-02-2008, 11:25 AM
Last journal entry: Body work
Here's the triangulated four link I built for my rambler. You wont need the pan hard bar if you do a triangular four bar and I would recommend using bushings of some sort and not rod ends at the bar attachment points.
Good Luck.
Ed
Old 01-02-2008, 11:56 AM
Thanks, that's exactly what I was looking for. Are the top control arms a certain angle or is it just triangulated to a point out in space towards the rear of the car?
Sean.
edit: I also was wondering are the bars parallel on the horizontal plane like a regular 4 bar, it doesn't seem to be in the pictures?
Old 01-02-2008, 12:59 PM
31 five window
Last journal entry: Moving along with patch panels.
I would also choose 4 bar over ladder bars. IMHO it will give a better ride and eliminate panhard bar.
Old 01-02-2008, 06:22 PM
pmeisel's Avatar
Glad the Jeep is on the road
Last wiki edit: How to identify a Ford V8
Sean.
http://home.earthlink.net/~whshope/
Check out fellow hotrodders.com member Billy Shope's website, he has several pages that will help you get better understanding of the whole topic.
Old 01-03-2008, 06:01 AM
The top arms should be as close to a 45 degree angle as you can get. The length and pivot points of the arms will change the instant center and effect how the rear suspension reacts.
Thump Thump in rear end?? HotRodMan Suspension - Brakes - Steering 7 01-24-2007 06:09 PM
Rear end identification 49dream Transmission - Rearend 4 08-25-2006 10:12 PM
Rear end ID ctown Transmission - Rearend 1 05-15-2006 10:20 AM
S-10/Camaro Rear End slaveforthewave Transmission - Rearend 7 02-20-2006 01:44 PM
Important rear end mounting question 71gtx Transmission - Rearend 2 01-04-2004 06:05 PM
