triangulated 4 link on a gm 10 bolt - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-25-2012, 08:14 PM
i did a quick search and couldnt really find what i was looking for, i have a gm 10 bolt that i would like to put a triangulated 4 link on, all the pics that i see and the directions ive looked up say to weld the top tabs to rearend housing, on the 10 bolt the housing is cast iron and i dont want to risk welding to that, can i weld the tabs to the axle tubes as close as possible to the housing? if i cant do that, could i possible weld in a bracket to the axle tubes that goes over the housing and weld the 4 link tabs to that?
any help on putting a triangulated 4 link on a gm 10 bolt is appreciated
thanx
Old 04-25-2012, 09:07 PM
Last journal entry: A few ongoing projects
Truthfully the easy way is to locate and use a 10 or 12 bolt from a GM car that was originally set up for a triangulated 4 link such as the A or G Body. They already have the brackets there.
triangulated 4 link drywall guy Suspension - Brakes - Steering 2 06-18-2007 01:59 PM
Triangulated four link 41willys Suspension - Brakes - Steering 18 10-26-2005 03:51 PM
Triangulated 4 link help?! jqmile Suspension - Brakes - Steering 14 10-19-2004 09:35 AM
4 link vs. triangulated 4 link. rear suspension bentwings Suspension - Brakes - Steering 4 11-23-2002 12:44 PM
Parallel 4 link or Triangulated 4 link rear ? RonWood Suspension - Brakes - Steering 1 11-13-2002 07:25 AM
