Triangulated 4bar/link ride quality lined heims vs poly bushings - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-20-2007, 02:34 PM
As I'm getting real close to the need to put a rearend under my '36 (Ford PU), I decided on a tri-4bar, but got to looking at didfferent rod ends and there's some that are teflon lined heims type, does anyne have any experience with these on the street? Or should i just stick with polybushing ends?
Thanks
Old 10-21-2007, 06:25 PM
Dugg's Avatar
My compass doesn't point North
Personally, I'd not use the teflon lined heim-type ends as I see the teflon lining be more superficial than structurally long lasting. I would also stay away from the cheap rod ends I see on ebay as they as most likely Cheap-Chinese-Communist-Conscripted-Child-Cruelty-Conflicting-Capitalism-Crap.
By good rod ends like Aurora's.
I'm using urethane bushings in a chrome-moly tube with a steel sleeve for a 1/2 bolt through the bushings. These tubes are TIG'ed to a grade 8 bolt that I have machined out to the 1.5" OD on the tube. If the picture loads you'll see it better.
So, just how important is using quality sandpaper? MARTINSR Body - Exterior 42 08-23-2006 08:32 PM
Poly vs. Rubber Bushings? Billy Boy Suspension - Brakes - Steering 6 04-28-2004 05:36 PM
