Trick Flow heads.....Should I go for them? - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-16-2003, 09:19 PM
Post Trick Flow heads.....Should I go for them?
Ok,
I have a 2 Bolt 350.
Bored .30 over with Hypereuctic pistons. Speed Pro. .125" Dome with the Anti-Friction Coating
Using the stock crank and rods.
Performer RPM intake. Plan on 1.6 Roller Rockers as well.
Cam is 230/230 and .480/.480..102 intake...110 lobe
I have a pair of 305 H.O heads on it right now but they are coming off. I plan on purchasing a pair of either the Twisted Wedge G2 heads or a pair of the 23 degree heads with the CNC-Chambers.
My question is, Should I shoot for them? AND, do you think I will make too much power for the rods/crank to handle?
The 305 heads are going bye bye no matter what. Dont want the headache they will give me. Hehe.
Old 01-17-2003, 05:18 AM
TurboS10's Avatar
Last wiki edit: Auto Terms and Definitions Used in Modern Engine T... Last photo:
Wiki Edits: 2
Post
I would go for it. I dont think with that cam you will make more power than what the parts will take. Those heads will also give you room to grow.
Chris
Old 01-17-2003, 11:51 AM
bullheimer's Avatar
NEVER use credit cards!
Post
there's some damn reason not to get the twisted wedges because you have to buy some other parts combinations for them or they need something else machined, but i'll be damned if i retained that knowledge, hopefully somebody else can help
Old 01-17-2003, 02:01 PM
Post
Hmm..
Well if you guys have any other suggestions for heads then let me know.
I would like to get the best pair I can for around $1200 or so..
If you can suggest a better intake to use with the heads, then let me know that as well.
Thanks
Old 01-17-2003, 02:02 PM
Post
Ahh yes..
If someone could throw out a Guesstimate as to what power I would see from my setup With the TrickFlow heads, thad be great.
(Just wanna see if my guess is the same as everyone elses)
Old 01-17-2003, 02:04 PM
bullheimer's Avatar
Post
well this i can tell you, in posts from the past, everybody just digs the hell of of the AFR's. they were used alot in the PHR engine masters challange. i think the guy who won used the twisted wedgies tho. all of those top engines cost about $15K plus to build tho.
Old 01-17-2003, 02:05 PM
TurboS10's Avatar
Wiki Edits: 2
Post
I think that trick flow is the best for anything other than an all out race engine. If you look at their flow numbers, they are alway higher than a comprable head with the same port volume. This means they will retain higher low end velocity with the smaller ports, and perform as well up top. Of course this is just what I have read, I have not yet actually owned a pair.
Chris
Old 01-17-2003, 03:10 PM
ronb's Avatar
Post
elelbrock and afr flow much better #`s right out of the box! trick flow will need some porting work to even get close to these!
Old 01-17-2003, 05:57 PM
1BAD80's Avatar
The Smell of Nitro in the morn
Last wiki edit: How to adjust valves Last photo:
Wiki Edits: 2
Post
A set of Dart Pro 1s will do the job. Make sure you have hardened pushrods and guide plates.
Luv the smell of NITRO in the morning.
Old 01-17-2003, 06:46 PM
TurboS10's Avatar
Wiki Edits: 2
Post
[quote]Originally posted by ronb:
<strong>elelbrock and afr flow much better #`s right out of the box! trick flow will need some porting work to even get close to these!</strong><hr></blockquote>
Got any info on this. This is not what I have seen. I would be interested to see a site or an article.
Chris
Old 01-17-2003, 09:29 PM
Post
I have read that the Trick Flows outflow most other heads out of the box. Hence the reason I may get them.
Old 01-17-2003, 09:42 PM
Post
The pistons I have are 10.85 Compression.
Now would I be better off getting a pair of Iron heads or Aluminum ones?
Have read on a few threads here that I would make more power with iron heads. Aluminum is lighter but more prone to warpage. (VERY EASILY)
Old 01-17-2003, 09:56 PM
Post
This engine is going in a 85 Ext Cab S15 Truck.
Looking to get LOTSA power but I dont want the power all up around 5000-7000RPM range. Would like it to be well evened out. Street/Strip is what is will be used for. Its not a daily driver and its not gonna be an all out dragster. More of a weekend street cruiser that I will take to the track alot during the summer.
Old 01-18-2003, 06:19 AM
TurboS10's Avatar
Wiki Edits: 2
Post
I would go aluminum if it is primarily race and weekend use. Just be careful and watch the temp closely. They will allow you to run more compression without detonation on top of the weight savings.
chris
Old 01-18-2003, 10:03 AM
Post
Cool.
Ill go that route then. Looks like the Trick Flow 23 degree heads are gonna be the ones.
Cant wait to see how this engine runs.
