trick flow stage 3 cam - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-03-2013, 08:58 PM
does anyone know if there are any special recommendations for a trick flow stage 3 cam for a ford, such as lashing or degreeing info, I do not have a cam card on this particular cam and haven't been able to locate one either.
it is a hyd. roller so it should be lash at "0" but I have seen hyd rollers with lash specs. if anyone has info on this cam any help would be great. thanks
Old 07-03-2013, 09:52 PM
techinspector1's Avatar
Wiki Edits: 326
Hydraulic roller tappet camshafts require the same initial adjustment that hydraulic flat tappet cams require. See this tutorial for instructions of how to do a Chevy......or any other motor that has an adjustable valvetrain.....
http://www.crankshaftcoalition.com/w...stment_SBC/BBC
Old 07-03-2013, 11:16 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Anytime you install a new cam w/higher lift and/or greater duration than the cam it's replacing, you should check a few things, like being sure the valve springs are up to the task (spring rate and coil bind).
That's a radical cam, the dual springs they recommend:
Part number TFS-16315-16, 1.460 in. diameter, 438 lbs. per in., 1.100 in. coil bind height.
More help on what to check:
Valve train points to check
Valve train geometry
Valve spring installed height
More info on adjusting your valves:
Adjusting hydraulic lifters
Don't know about a cam card, you can contact TFS and I'm sure they can hook you up. Meanwhile, some numbers:
Advertised duration: 298 degrees intake/ 325 degrees exhaust
Duration @ 0.50" lift: 236 degrees intake/248 degrees exhaust
Lift: 0.574 intake/0.595 exhaust
Lobe separation angle: 110 degrees
Old 07-05-2013, 03:09 PM
thank you gentleman
Trick Flow's on a SBC 19nova69 Engine 6 11-06-2010 05:24 PM
AFR Vs. Trick Flow mesterious Engine 5 01-18-2010 01:01 AM
trick flow heads 4doorjoe Engine 2 07-30-2005 08:09 PM
Trick Flow Heads Turkey Engine 3 08-13-2004 06:36 PM
Trick Flow Heads Turkey Engine 1 08-12-2004 07:17 PM
