Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - A trick I do for hanging doors
Old 09-24-2012, 10:12 PM
tech69 tech69 is offline
put up or shut up
good idea, and reminds me of drilling holes in the hinges and using punches to re-align it up. Sort of the same concept. You can also lay it in it's hole and latch it shut and your holes will be lined up or close enough to get bolts in. I do that once in a while, mainly on pillar jobs where I have to pull where the door mounts and then you want to mock it up to see how it fits around your a-pillar/rocker/etc after you have pulled. With the car on the rack, a gutted door that's light, and no one to help, latching it shut works pretty good.
