Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - A trick I do for hanging doors
Old 09-24-2012, 10:33 PM
Lizer Lizer is offline
Good idea, I'm thinking then remove one of them on each hinge and put a bolt to tighten as you adjust the door then remove the other studs, very good idea.
yep. As you can see there are only two studs per hinge. Since two of the three are line up, the third one will be lined up as well to put the first bolt in the empty hole. Then just go around, remove the studs and replacing with the bolt.
