A trick I do for hanging doors - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-24-2012, 09:50 PM
Thought I'd just post a trick I do when I'm hanging the doors on my 67 Mustang. Anybody familiar with these know the threaded metal plate behind the door jamb isn't always attached and can fall down.
I cut the head off some 5/16-18 bolts and screw them in loosely. They serve three functions:
1. Serve as guides for setting the hinges on
2. Prevent the metal plate from falling
3. Give you leverage to move the plate around to line it up with the bolt.
By the way, these same bolts will also work great for when you need to set an intake manifold on top of the engine. Screw these in to the top of the block at each corner and use them as a guide. Will set the intake down perfectly straight.
ID:	68117   Click image for larger version
Old 09-24-2012, 10:10 PM
Good idea, I'm thinking then remove one of them on each hinge and put a bolt to tighten as you adjust the door then remove the other studs, very good idea.
Old 09-24-2012, 10:12 PM
put up or shut up
good idea, and reminds me of drilling holes in the hinges and using punches to re-align it up. Sort of the same concept. You can also lay it in it's hole and latch it shut and your holes will be lined up or close enough to get bolts in. I do that once in a while, mainly on pillar jobs where I have to pull where the door mounts and then you want to mock it up to see how it fits around your a-pillar/rocker/etc after you have pulled. With the car on the rack, a gutted door that's light, and no one to help, latching it shut works pretty good.
Old 09-24-2012, 10:33 PM
yep. As you can see there are only two studs per hinge. Since two of the three are line up, the third one will be lined up as well to put the first bolt in the empty hole. Then just go around, remove the studs and replacing with the bolt.
Old 09-25-2012, 05:10 AM
jcclark's Avatar
The Penny Pincher
Last journal entry: Hanging Bumpers
Also:
I usually drill a 1/8" hole through the hinge before removing them.
When I reinstall I insert a 1/8" drill bit or rod and it gets me back
to original alignment pretty fast.
Brakes hanging up dilligaf Suspension - Brakes - Steering 4 04-12-2012 07:17 AM
GM 3.4L hanging valve? fast68 Engine 2 05-25-2010 05:57 PM
Brakes hanging up choirboy Suspension - Brakes - Steering 6 04-12-2009 08:06 PM
hanging 1/4 panel mitmaks Body - Exterior 0 05-08-2007 08:46 PM
Hanging a quarter? Fixer1 Body - Exterior 10 07-29-2005 07:22 PM
