Trick TH350 for a dirt track car...... - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-04-2010, 08:49 PM
How would I go about hollowing out a 350 tranny to be direct drive(with some kind of clutch mechanism) to run in a dirt track car? I'm thinking no loss of power thru normal slipping of AT, plus a really good way to run a very light flywheel! Need to get this by tech if possible. I have heard of this mod to a Powerglide...but not a TH350. How to do it is the big question.
Thanks
6sally6
Old 02-04-2010, 10:38 PM
SSedan64's Avatar
In the one I saw the internal clutches were still used. The Torque converter was replaced with a Centrifugal clutch.
Old 02-05-2010, 09:15 AM
Was it a TH350? The reason I ask....I have "heard" several references to doing this trick to a Powerglide, but not a TH350. We can run either tranny in the class....just need further info on how-to-do-this-mod. Seems like it would be like using a standerd drive with a very light clutch!
Any more suggs?
Thanks
6sally6
Old 02-05-2010, 10:06 AM
SSedan64's Avatar
Yes, it was a TH350, I've heard of this done to Glides also. There's a few old threads on here about something similar but, I think I remember it used a Dummy Torque Converter and other Pump Mods. Not sure if parts are still available. Try doing a search in the Trans/Rear section. I'm sure someone will know more about it than I do.
Old 02-05-2010, 10:58 AM
SSedan64's Avatar
TCI Circlematic
http://www.tciauto.com/Products/Circ...nsmissions.asp
http://www.tciauto.com/Products/Circ...ump_drives.asp
http://www.tciauto.com/Products/Circ...components.asp
http://www.maverickperformance.com/
http://www.wintersperformance.com/ca...eWinder/03.htm
Today for the first time I judged a car show. MARTINSR Hotrodders' Lounge 7 06-07-2008 05:45 AM
dirt track 305 groomer Engine 12 04-20-2008 02:46 AM
Three different paint shops suggested 2 different ways of painting the car, opinions? Ripped Body - Exterior 8 04-30-2007 02:05 PM
Story time. Halloweenking Hotrodders' Lounge 17 05-19-2003 10:16 PM
4 CYL OVAL TRACK RACE CAR 4doorjoe Hotrodders' Lounge 3 02-11-2003 07:25 AM
