Trick of the week - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-09-2013, 07:41 AM
deadbodyman's Avatar
Wiki Edits: 11
Trick of the week
have you ever used cutting oil when drilling out a few hundred/thousand spot welds? Then you know its gonna tip over and spill at least once or twice a day so heres what I came up with ...get some foam from old couch or chair cut a piece to fit tightly inside the can then fill the can with your oil..it will never spill again..
Lets see some of your favorite tricks....
ID:	104522   Click image for larger version
The Following 4 Users Say Thank You to deadbodyman For This Useful Post:
Joe G (12-09-2013), killeratrod (12-09-2013), naka (01-12-2014), raidmagic (12-09-2013)
Old 12-09-2013, 10:02 AM
Ain't you smart. I am going to do this.
John
Old 12-09-2013, 10:55 AM
Rick 5150 69's Avatar
Great tip, you could also glue a magnet to the bottom side so it would require xtra force to knock over.
Old 12-09-2013, 01:27 PM
Banned
neat tip, thanks. i guess i can get rid of the little lady now, she will no longer be needed to hold thinks like this. LOL
Old 12-09-2013, 02:13 PM
geezer69's Avatar
Die standin' up
Last journal entry: geezer69 nova 63
goodun ....
Old 12-09-2013, 02:36 PM
Wiki Edits: 11
John
Not so smart John ....but very "Frugil" ..That stuffs expensive,
not only that when you do knock it over its going to spill on your tools or inside the car ,basicly,right where you need to be..... what a PITA ...
The Following User Says Thank You to deadbodyman For This Useful Post:
John long (12-09-2013)
Old 12-09-2013, 02:42 PM
put up or shut up
I like it! I usually just use air tool oil on my bits but that's so much better. Thanks for sharing.
Old 01-10-2014, 05:50 PM
Olcarguy's Avatar
Last journal entry: 52 Chev Panel Baskett Case
I use old bacon grease as cutting oil, it stays relatively hard and doesn't run. Cheap and smells good too.
Old 01-10-2014, 08:40 PM
Thank you sir, I'll do this the next time I'm drilling
Old 04-30-2014, 07:10 AM
Wiki Edits: 11
I've improved the design of my hi tec cutting oil can , LOL......I bought one of those small HF magnetic bolt trays and set the can in it...the can sticks to the tray and the tray sticks to any metal surface so it can be inches away from where your working ,and it has a second advantage, you now have a special place to keep the drill bits and chuck key....much better than just a can .....
John long (04-30-2014)
Old 04-30-2014, 11:51 AM
This is my tip, and I know all of you have plenty of these.
Old 04-30-2014, 02:33 PM
Great idea. I think I will run out and buy some beer right now.
Old 04-30-2014, 04:14 PM
Wiki Edits: 11
Ya know...,...I was getting a bit thirsty too....Good idea....
Old 05-01-2014, 02:30 PM
charchri4's Avatar
Jim Stainer
Great idea! Mine is in a little squeezy bottle. The bottles musicans use for slide oil work excellent but so do stolen ketchup bottles from white castle. Theoretically I mean...
Bonehead trick willys36@aol.com Hotrodders' Lounge 16 09-25-2011 12:31 PM
Is there a trick to this? trifivefan Interior 2 05-31-2008 04:45 AM
Who has a tip or trick to get this off? GMW Body - Exterior 2 12-17-2006 05:25 PM
TRICK or TREAT... Dave E Shank Hotrodders' Lounge 28 11-02-2003 11:22 AM
Mirror trick Gr8 '48 bow tie Hotrodders' Lounge 3 10-15-2003 09:36 PM
