tries to stall in gear th350 - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-28-2011, 11:21 PM
ok so i have a odd problem going on an i dont know whats going on. I think i might have a locked up converter. Whats going on is that car start idles revs fine. Drives fine but the thing is when i put it in gear it tries to kill itself. My ilde is set at 1500 an when i put it in gear drive/reverse the idle drops to 300ish an tries to die i hold the brake an the converter will not slip i can not power brake it to raise the idle. I was leaning toward my converter is locked another reason i think this is the car died the other day in gear an insted of letting it spin free the motor kept spinning. Like in a manual when i shut the car off an let the clutch out.
Old 10-02-2011, 09:00 AM
Last journal entry: gettin closer and closer
yep change the converter
TH350 2400 Stall Questions Bonger6 Transmission - Rearend 11 07-10-2010 11:52 PM
TH350 stall? chrome1021 Transmission - Rearend 1 03-18-2009 06:16 PM
What stall is needed for my TH350 / vortec 350 307malibu Transmission - Rearend 5 02-15-2008 03:55 PM
Th350 shifting and stall problem sack Transmission - Rearend 2 09-14-2004 08:12 AM
Lock up TH350 Stall Convertors toooofastforu Transmission - Rearend 4 06-23-2004 05:13 AM
