Trim Hole Welding - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-06-2006, 11:35 AM
52 RAT's Avatar
52 RAT
Trim Hole Welding
Iam going to begin welding the trim holes on the Rat Project.. I have read all of the posts in regard to tips and tricks. I have an old cooper hammer to back the holes while welding but there are those tight space holes that the hammer head just can't reach. I have various size scraps of round solid brass stock that could fit these tight spots but a few of the threads warned against using brass to weld the holes.... WHY? I appreciate any additional information...
Old 10-06-2006, 11:50 AM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
Maybe the brass deal has something to do with brazing the holes..For those holes you can't get the hammer into take a piece of copper pipe and hammer it flat and wedge it in there is what I would do..you can use that piece of pipe over and over..
Sam
Old 10-06-2006, 12:18 PM
Beenaway2long's Avatar
or Jeff, or Doc, or...
Last journal entry: Results of the Camaro
I use a penny or a piece of copper water pipe. Depending on what fits.
Why not use a small piece of sheetmetal, if it will be hidden??
Old 10-07-2006, 10:04 AM
BRASS WILL MELT. COPPER WILL NOT PLUS YOUR WELD WILL NOT STICK TO IT. YOU NEED TO WELD FROM THE INSIDE WITH THE COPPER ON THE OUTSIDE. THIS WILL GIVE YOU A SMOTH FINISH SO YOU HAVE ALMOST NO FILLING OR SANDING.
BILL
Old 10-08-2006, 09:23 PM
jimk's Avatar
Yeah don't use brass.I got some copper from home depot.Cost me about $1.50 and I was good to go.
Old 10-08-2006, 10:26 PM
powerrodsmike's Avatar
Wiki Edits: 161
I use aluminum as a backup also. I know it works with mig and tig.
later, mikey
BE different....ACT normal.
"Basic of Basics" Welding - How do I repair body panels? Centerline Body - Exterior 33 03-31-2014 09:45 AM
Welding info Kevin45 Body - Exterior 10 08-26-2011 08:09 AM
welder reccomendations? rally4x4racer Garage - Tools 32 10-14-2008 09:00 PM
Parasol Metal body filler. x711 Body - Exterior 16 02-14-2006 09:47 AM
Welding Books Magnus_Jager General Rodding Tech 6 11-29-2005 03:57 PM
