Trim panel board material? - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-30-2013, 09:31 AM
I know I have been told where to get this material here but I lost the link. But I am also wondering if they have a minimum or some other reason to throw a wrench in the transmission would something like tempered Masonite work ok for the package tray in my Rambler?
Old 09-30-2013, 10:00 AM
Northstar T's Avatar
Gone sailing
I buy 4"x8' sheets from my local lumber yard. 1/8" thick ply similar to door skin material. they have a name for it that alludes me at the moment, but I just ask for 1/8" plywood and they know what I want . last sheet was $18.00 as I recall. it has exterior glue, but I coat mine with varathane just for insurance. I just made a set of inner door panels for the 62 with it last week in fact. going in for upholstery tomorrow
Russ
Old 09-30-2013, 10:30 AM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
That door skin material is very useful..I make templates for parts out of it as well as it holds its shape..A sheet of that stuff never goes to waste..
Sam
Old 09-30-2013, 10:37 AM
496CHEVY3100's Avatar
Built Not Bought
Last journal entry: 53 ad3100
Luan
Russ
I think you are talking about ,Luahn --luan - if I spelled ir correct
John gave me a piece of material that would be perfect ,you will have to ask him the name ,,it is used for sign board ,
Old 09-30-2013, 10:45 AM
DanTwoLakes's Avatar
Wiki Edits: 22
Brian: Why does everybody want to use home building products to do upholstery work? The worst thing you can use in a vehicle is Masonite. When it gets damp it turns to mush, even the "tempered" kind which is just oil treated. It can also warp, or because it's so brittle, it can break where you attach it. Use 1/8" waterproof panel board or PVC foamboard for your package shelf. If it was me, I'd use the waterproof panel board. You won't find it at Home Depot or any other home building supply store. You buy it from an upholstery supply house. Any upholstery shop should be able to get it for you or have it in stock. If you can't find it online or near you, let me know and I'll send you a piece. Here's a link to show you what I'm talking about: http://www.perfectfit.com/15347/1545...anelboard.html
Old 09-30-2013, 10:50 AM
Wiki Edits: 22
Originally Posted by 496CHEVY3100 View Post
Luan
"......John gave me a piece of material that would be perfect ,you will have to ask him the name ,,it is used for sign board ,
You are talking about PVC foamboard.
Old 09-30-2013, 10:51 AM
Built Not Bought
Yea that is it ,looks like a high density foam board you can staple glue it and it is waterproof
Old 09-30-2013, 11:59 AM
Originally Posted by DanTwoLakes View Post
Brian: Why does everybody want to use home building products to do upholstery work? The worst thing you can use in a vehicle is Masonite. When it gets damp it turns to mush, even the "tempered" kind which is just oil treated. It can also warp, or because it's so brittle, it can break where you attach it. Use 1/8" waterproof panel board or PVC foamboard for your package shelf. If it was me, I'd use the waterproof panel board. You won't find it at Home Depot or any other home building supply store. You buy it from an upholstery supply house. Any upholstery shop should be able to get it for you or have it in stock. If you can't find it online or near you, let me know and I'll send you a piece. Here's a link to show you what I'm talking about: Kraft Tan Waterproof Panelboard
Thanks guys, Dan, I'll check here locally with a shop. Thanks again!
Old 09-30-2013, 05:53 PM
Gone sailing
I recently bought my window run material (fuzzy velcro) from a sewing center. does that mean my windows will fall out now?
Actually that panelboard looks pretty slick. I may try some next time. I've been using this 1/8" ply for 20 years or so, ever since a local upholstery shop recommended it to me (they used it also). never had a problem with it, but I'm not opposed to trying something new.
Russ
Old 09-30-2013, 05:57 PM
Dan is correct guys. It was PVC panel board I gave David. I know of nothing better. Best of all I paid 22 dollars for a 4X8 foot sheet. It glues, staples, bends, and shapes with heat. It is water proof and light. Is there anything else you would want it to be?
John
Old 09-30-2013, 09:23 PM
Wiki Edits: 27
Keystone
My son used to work for Keystone when they were in santa clara. they have moved closer to you. now in Fremont. they used to be wholesale only but you are in the "business"
Old 09-30-2013, 09:26 PM
I'll look into it anyway, I do work at a body shop maybe they would let me buy it that way? Hmmm, we will see, thanks.
Old 09-30-2013, 09:29 PM
Wiki Edits: 27
They moved again
Now in hayward
Hayward, CA Keyston Bros.
Old 09-30-2013, 09:31 PM
Thanks!
Old 09-30-2013, 09:42 PM
There Web site shows a location in San Francisco.....
Panel Material crsweet91 Interior 8 11-13-2012 10:41 AM
Interior door panel material 2stroketurbo Interior 17 03-18-2007 08:25 PM
headliner board material bentwings Interior 15 04-05-2006 07:47 PM
Running Board Trim 5window Body - Exterior 1 01-06-2004 01:43 PM
Whats the best material for making a headliner board? Jag Daddy Interior 4 10-09-2003 06:52 PM
