Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Trivia thread
Thread: Trivia thread
  #527 (permalink)
Old 02-09-2009, 04:01 PM
Chris Kemp Chris Kemp is offline
Originally Posted by Joe G
Sometimes I wonder about Wikipedia......
Thanks for the insight, Brian. Steering geometry is a complicated subject, and I still have a lot to learn about it.
Next question:
When disconnecting a battery on a vehicle with a negative ground electrical system, Why is it safer to disconnect the negative battery cable first and re-connect it last?
To avoid a short from the hot post to any surrounding metal. If you take the negative off first you don't have to worry about bumping the wrench to the fire wall or core support or anything else when you remove the cable off the positive post.
