You're right Brian. It was 61-62 that did the different trim rings. I give up on the 63-64 deal.
changed color?
'63 used fiberglass headlight buckets and '64 used metal.. is that what your looking for?
Different type of screws to hold them in?
"When I was younger, I could remember anything, whether it had happened or not." - Mark Twain |
Brian |
can't think of any good 1's.. so heres a fairly easy 1..... How long was the cam timing chain on the SOHC Ford 427 " Cammer "?
6 feet and a link
you got it. |
Tech question:
What is the difference between Bendix and center plane brakes and what is the advantage of the latter. |
My education said that the Bendix are self energizing in that the are really not connected to the backing plate by anything but the hold down springs and restricted in rotational travel by the stationary pin. The, upon application tend to try to follow the brake drum and wedge themselves tightly to that drum. The more brake pedal pressure, the tighter they wedge. The other style, and what were/are called Lockheed are held tightly, usually at the bottom with the pedal pressure to the fluid being the only activation force. Pre '49 Fords and MoPars through at least '56 or later, I believe, used this system or a variant in the late MoPars, and they used double wheel cylinders with 2 opposing double pins/posts or in some cases, stepped cylinders. They required an involved two part adjustment The MoPar's were without a doubt, crap brakes(much personal experience fixing them). There is NO advantage
Really close. Want to try again?
Nobody? Ok. True center plane brakes, have two cylinders and two anchors causing each shoe to act as a leading shoe providing for self energising full shoe contact.
Downside- Short lining life, grabbing, noise and difficult adjustment. OK IC, your floor |
Why do I do this to myself!!!
Corvairs had a problem keeping the shiny side up on the early models (remember Ralph Nader's 'crusade' book"Unsafe at Any Speed"??) GM made the first change in_____ . They then upgraded it again in _____ ? What was it called? Dave W (Three separate roll overs injured friends of mine ) |
| Tags |
| humor, trivia |
| Recent Hotrodders' Lounge posts with photos |
| Currently Active Users Viewing This Thread: 2 (1 members and 1 guests) | |
| Silver Surfer |
| What Type of thread? | fe428fairlane | Hotrodders' Lounge | 5 | 06-10-2002 02:49 AM |
