Trivia thread - Page 166 - Hot Rod Forum : Hotrodders Bulletin Board
  #2476 (permalink)
Old 02-25-2011, 01:37 AM
dinger's Avatar
Doh!
"When I was younger, I could remember anything, whether it had happened or not." - Mark Twain
  #2477 (permalink)
Old 02-25-2011, 06:05 AM
OLNOLAN's Avatar
Hints
Here are some hints; Bob has 3 parts correctly named, Dan has 1 part correct, fuel injection was not allowed at NASCAR tracks, there are actually 6 part types with 7 different part numbers, I stumbled on to this supplemental information while looking for something else about a '57 Chevrolet. nolan
  #2478 (permalink)
Old 02-25-2011, 06:14 AM
OLNOLAN's Avatar
ha ha
Originally Posted by dinger
Is this what you're looking for?
"Twenty-gallon tank has increased fuel capacity. Unit is complete with necessary filler neck, hoses, clamps and straps. Mounts same as standard tank..." Group 3.001, PN 3744079
In the photo, it shows two additional mounting straps going side-to-side.
Rear Axle. The rear end is is the drop-out carrier style, and has a removable back cover. It's also been braced, with a piece of tubing or solid rod going under the housing, side-to-side.
Axle Unit, Rear
Group 5.386, Part No. 3744020
"Unit is interghangeable with standard rear axle. Existing attaching parts can be used. Shop Manual overhaul procedure for the 1/2-Ton Truck axle is applicable."
Group 5.809, Hub and Drum Assy, Front Wheel. PN 3725816
Group 6.020, Knuckle, Steering, with nut. PN 3725025
Group 6.103, Arm, Steering Knuckle, LH PN 3729295
RH 3729296
Group 6.307, Hub, Front Wheel, PN 3744428
If you found this, you probably stumbled right over the source of my question. nolan
  #2479 (permalink)
Old 02-27-2011, 07:02 AM
OLNOLAN's Avatar
Hint
1957 Grand National
  #2480 (permalink)
Old 02-27-2011, 08:01 AM
The "Black widow"?
  #2481 (permalink)
Old 02-27-2011, 01:38 PM
35terraplane's Avatar
trivia
The "Black widow"?
I agree with Brian, the car was known as the Black and White in NHRA, when it got built for NASCAR they became known !st as the Dontov 150 or car. then they became the Black Widow.
The cars were built by SEDCO out of Atlanta, They came to speed week in 1957 with FI on them and ran with it, after the 500 NASCAR outlawed FI.
Buck Baker drove one to the championship in 57 with a 4bbl carb on it.
They also had a rearend with 6 lugs on it. SEDCO made other colors but the black and white ones were the Black Widow.
If I got three of the parts right I don't even know which 3, it was just what I found, Part # I don't have a clue.
Bob
It's a great question Nolon. IT must be it has me stumped. LOL
  #2482 (permalink)
Old 02-27-2011, 02:15 PM
1969NovaSS's Avatar
turbo lag......yeeeeehaaaaaaw
Im going to guess if these are the right parts:
5231585-solid lifter
3736097-camshaft
1115091-coil
1931385-resister
1110905-distributor
1918148-points
3731803-lh motor mount
3731804-rh motor mount
  #2483 (permalink)
Old 02-27-2011, 07:19 PM
OLNOLAN's Avatar
Black Widow
The "Black widow"?
If you follow up on the Black Widow you will find the link. Think old cars. olnolan
  #2484 (permalink)
Old 02-27-2011, 07:29 PM
OLNOLAN's Avatar
yep
3736097-camshaft
1115091-coil
1931385-resister
1110905-distributor
1918148-points
69 nova ss, nailed two more parts, correct part numbers too. olnolan
  #2485 (permalink)
Old 02-27-2011, 07:33 PM
OLNOLAN's Avatar
ha ha
Bob
think old car, the link is there. olnolan
  #2486 (permalink)
Old 02-28-2011, 12:52 PM
trivia
That's all I can do is think old.
Bob
I will look some more,
  #2487 (permalink)
Old 02-28-2011, 03:56 PM
Joe G's Avatar
Registered user
....Ok, This one will be fun and easy. In 1957, NASCAR allowed these Chevrolet engine parts. There were seven(7) different part numbers(GM). What were the parts and the part numbers to make it a little harder.
I found this in the "1957 Chevrolet Stock Car Competition Guide"
Part No. Description
3736097 Special Performance Camshaft
3749664 Gear - Sprocket, Camshaft Timing
3746289 Notched Piston, with pin, L.H.
3746290 Notched Piston, with pin, R.H.
3837002 Valve Spring and Damper
5231585 Valve Tappet (Mechanical type)
*3749666 Carburetor Assembly
*Specially calibrated four-barrel carburetor required with the special performance camshaft.
If that ain't the answer, I give up.....
  #2488 (permalink)
Old 02-28-2011, 07:36 PM
OLNOLAN's Avatar
Yep, Thats It
You got it Joe, Thats what I'm talking about! I thought it was kinda funny that NASCAR outlawed the fuel injection, then Chevrolet had to do a supplement on the NASCAR ALLOWED components.
You have the floor. Nolan
  #2489 (permalink)
Old 02-28-2011, 08:50 PM
Joe G's Avatar
Registered user
That was a great question, Nolan.....
Here's one that really is easy.....
Name the year, make, and model of this car:
  #2490 (permalink)
Old 02-28-2011, 09:31 PM
richard stewart 3rd's Avatar
Last journal entry: 351W rebuild
Hi
1934 Oldsmobile 4dr sedan
Rich
humor, trivia
Currently Active Users Viewing This Thread: 3 (2 members and 1 guests)
496CHEVY3100, boothboy
