Trivia thread - Page 36 - Hot Rod Forum : Hotrodders Bulletin Board
  #526 (permalink)
Old 02-09-2009, 02:58 PM
I learned about Ackerman many years ago fooling around with dirt cars. It can actually cause the inside tire to drag when the car is going through a turn. So I learned to heat the steering knuckle up and reshape them to remove Ackerman. Sounds crazy but it worked great. It was introduced so that the front tires would not squeal when you were making a tight slow turn on an asphalt parking lot. You guys amaze me.
  #527 (permalink)
Old 02-09-2009, 03:01 PM
Originally Posted by Joe G
Sometimes I wonder about Wikipedia......
Thanks for the insight, Brian. Steering geometry is a complicated subject, and I still have a lot to learn about it.
Next question:
When disconnecting a battery on a vehicle with a negative ground electrical system, Why is it safer to disconnect the negative battery cable first and re-connect it last?
To avoid a short from the hot post to any surrounding metal. If you take the negative off first you don't have to worry about bumping the wrench to the fire wall or core support or anything else when you remove the cable off the positive post.
  #528 (permalink)
Old 02-09-2009, 03:06 PM
Joe G's Avatar
You are correct.
Chris, the floor is yours...
  #529 (permalink)
Old 02-09-2009, 03:21 PM
That's kinda like custom paint, taking a screwup to work for you! It adds drag, makes sense to do that to the inside wheel to "pull it" into and thru the corners.
  #530 (permalink)
Old 02-09-2009, 04:15 PM
What type of doors does this car have?
In this picture we have a car with an unusual type of doors.
What was the name that was originally given to them?
Who was the automobile designer that created them?
What car and car manufacture were they first installed on?
And what year was it?
  #531 (permalink)
Old 02-09-2009, 04:24 PM
Actually you did not want it to drag because that could make the car have over steer or be considered loose in the rear end. We would heat the knuckles and reshape them to remove Ackerman so that the front end would roll through the turns. We would shift the added weight, adjust the springs or change the rear geometry to tighten or loosen the car in the turns.
But yeah you're right about screw ups in paint becoming custom paint. Two that I can think of are cob-webbing and the bowling ball, you can probably come up with more.
  #532 (permalink)
Old 02-09-2009, 10:15 PM
Again, the multiple questions! Which one gets me the brownie button?
1. Beetle wings?
2. Marcello Gandini
3. Lamborghini Carabo
4. 1966
This is all out of a Lamborghini Countach book I have. It doesn't say they were the first, but I am thinking that they were.
  #533 (permalink)
Old 02-10-2009, 06:21 AM
1. Beetle wings?
2. Marcello Gandini
4. 1966
We may have mixed info. But thats ok cause you got the designer right and you didn't say the obvious which would have been "Lambo doors, Lamborghini Countach".
According to Wiki you got the name of the car but the manufacture was Alfa Romeo Carabo Concept: http://www.ultimatecarpage.com/car/2...o-Concept.html Be sure to check out the images because it sure was a wicked looking thing!
Wiki calls these doors: Scissor doors, beetle-wing doors, jack-knife doors, and switchblade doors. Check it out, a very interesting read:
http://en.wikipedia.org/wiki/Scissor_doors
Brian you now have the floor!
  #534 (permalink)
Old 02-10-2009, 07:52 AM
I guess he was working for Bertone at the time and in my book they put a few Lambos and the Carabo in the same sentence only saying "Alfa Romeo chassis". That's funny because I know that car very well from a "Dream car" book I have had for years but I didn't know the name of it. It is striking isn't it?
You know how much I love Small block Chevys , what is regarded by many as the very first small block chevy engine swap?
  #535 (permalink)
Old 02-10-2009, 09:56 AM
Dream Truck
The "Dream Truck" the creation of the persistent leadership of Spencer Murray the first editor of Rod & Custom magazine was the first vehicle to receive a documented small-block Chevy engine swap. The project started with custom modifications, performed by a who's who of customizers, on a factory-fresh 1954 Chevy truck cab. Sam Gates chopped the top 3-3/8 inches and sectioned the body 5-1/3 inches. Neil Emory and Clay Jensen of Valley Custom finished the chop and sectioning work, and hand-formed the beautiful dashboard. Curly Davis finished the dashboard, integrated it into the door design, and widened the rear window. After Gene Winfield radiused the front-wheel cutouts and sectioned the hood, Barris Kustom added quad headlights, scoops to the roof and hood, and front and rear grille openings formed by molding together '54 Stude�baker front pans. Bob Hirohata added the clear front and translucent red rear turn-signal lights. Later, Bob Metz formed the wild scratch-built canted fins. Each of these craftsmen proved integral in the development of the truck.
I know all of this because I helped on the restoration of it in 1980.
Here's an old picture of it that I scanned into the computer.
  #536 (permalink)
Old 02-10-2009, 11:09 AM
Very cool, and right on the money! My brother rebuilt the carbs on it during that rebuild. That truck meant a lot to me, being I have one. I got it when I was 15 and chopped the top four months into my 16th year using the "little pages" article on chopping the Dream Truck. When that truck was first shown after the rebuilt at the SF Roadster show I was so excited to see it and took a number of photos.
It is a work of art.
It is your floor Chris!
  #537 (permalink)
Old 02-10-2009, 11:40 AM
Brian, I was just yanking your chain so to speak about having worked on the restoration of it. I wasn't there LOL. I wasn't born until 1957 but I do remember seeing pictures of it from old magazines in the sixties. But I was not aware that it was the first documented sbc swap and thanks for that info. A couple of weeks ago I had read an old post that you had put up about it and today I did a search on it. I found a good web site about it, snipped a picture and then made it look old and faded in photoshop LOL. Check the link out good reading: http://auto.howstuffworks.com/dream-...custom-car.htm
I have to get ready for work so give me a couple of hours and when I get everything under control at the shop, I will up-load another question.
  #538 (permalink)
Old 02-10-2009, 04:07 PM
Trucknut's Avatar
If nobody has a question....I have one.
What American auto maker offered self balancing wheels in the mid-sixties? This was done by using ball bearings floating in a tube around the inside of the wheels.
  #539 (permalink)
Old 02-10-2009, 10:19 PM
I have used these things on semi tractor trucks but I can't remember the name of the company that made them. But I wasn't aware that a car company offered them.
  #540 (permalink)
Old 02-10-2009, 10:44 PM
I don't know about the self balancing tires but what about your question Chris?
humor, trivia
Currently Active Users Viewing This Thread: 3 (1 members and 2 guests)
dinger
