Trivia thread - Page 414 - Hot Rod Forum : Hotrodders Bulletin Board
  #6196 (permalink)
Old 02-16-2013, 12:28 PM
These strikers are from a Chevy "AD" 1947-1954 pickup. Why the three? What applications where they used? And note that they are not all the same side. The two on the right are for the right door the one on the left is for the left door. I couldn't find the right side version of the one on the left. So just look at the function of them not how that one on the left is a different side.
  #6197 (permalink)
Old 02-16-2013, 01:38 PM
Originally Posted by BigEsGarage View Post
1953 Kaiser, Dragon.
That what it is!
What do yo know about the car?
ID:	71430   Click image for larger version
ID:	71431   Click image for larger version
ID:	71432   Click image for larger version
  #6198 (permalink)
Old 02-16-2013, 03:18 PM
496CHEVY3100's Avatar
Big boys wear Bowties
Last journal entry: ,
I have 3 of these trucks at home and 3 in shop customer trucks all exept one has latch on right i am guessing they are original <my personal truck has one on lefr they are repo from LMC ,may not be the answer you are lookin for but its the only Guess i have.
  #6199 (permalink)
Old 02-16-2013, 05:59 PM
They are all original, and in fact taken off trucks before there were even repos available. Nope, there is a distinct reason they are different. They aren't different because they are just different, they have different functional differences.
  #6200 (permalink)
Old 02-16-2013, 07:01 PM
I looked at my trucks again my 53 has the ones on right with slotted adjusters ,,the rest are 51 50 and 49 they have round holes with slots in door frame the 54 does not have these on it at this time but from door frames they appear to be slotted type latch like on right ,.probably not what you are looking for ,
  #6201 (permalink)
Old 02-16-2013, 08:07 PM
So where is the one in the middle used?
  #6202 (permalink)
Old 02-16-2013, 08:47 PM
Are they all interchangeable, meaning will they all work on the on the same year truck? If not I would assume that a latching problem or design fault needed to be rectified. That or searching for the least costly part.
BB
  #6203 (permalink)
Old 02-16-2013, 08:58 PM
Well BB, they do not all fit on all the cabs as pointed out, the two on the right fit on the later cabs while the one on the left is for the early cabs. Why is this and why the middle one?
  #6204 (permalink)
Old 02-16-2013, 11:42 PM
Well I'll stick to my original answer.
BB
  #6205 (permalink)
Old 02-17-2013, 01:57 AM
rear door surburban and carryall
  #6206 (permalink)
Old 02-17-2013, 08:49 AM
Nope, there was no design flaw and they all are from the doors of pickups. I'll give you all a hint.
The cab where the striker mounted changed when the door handles went from swing to push button. There is your hint, but why the one in the middle?
  #6207 (permalink)
Old 02-17-2013, 10:00 AM
The one on the left is from a earlier AD truck. The one on the right is for a later AD truck. (All within 1947-1954.) 51 would be the last year for the early unit and 52 would be the first year for the newer unit. The exterier handles went from a pull type to a push button
The one in the center is a later unit that has been modified to work on a earlier truck.
BB
  #6208 (permalink)
Old 02-17-2013, 10:20 AM
Nope, you are missing the point but are on the right track. The one in the middle won't bolt onto an early cab that had swing handles. It will only bolt on the later cab that was made for push button handles.
So what is with the middle one?
  #6209 (permalink)
Old 02-17-2013, 10:37 AM
Brian your right. I don't understand what your looking for. All three have the exact same function. To hold the door closed. We have a early and late design that are different because the latching mechanism is different because the out side door handle is different. ( Note classic run on sentence ). Now as to the middle one, I'm working on it. The middle one has not been modified?
BB
  #6210 (permalink)
Old 02-17-2013, 10:41 AM
52 and newer have locking doors 51 and erlier do not could be the only thing i can think of.
humor, trivia
