Trivia thread - Page 68 - Hot Rod Forum : Hotrodders Bulletin Board
  #1006 (permalink)
Old 04-28-2009, 09:09 PM
Semper Gumby
Wiki Edits: 2
Trivia
OK - if this is all just gonna sit there -
On a sparkplug, there is the portion of the insulator that sicks up ABOVE the "base" (the other end protrudes into the cylinder etc) - What brand of spark plug was readily recognizable because theirs were PINK?
  #1007 (permalink)
Old 04-29-2009, 12:32 AM
540neverdone's Avatar
Loves to spooge
Was it Autolite? Making plugs for Firestone.
  #1008 (permalink)
Old 04-29-2009, 04:12 AM
mercmad63's Avatar
Last journal entry: An update
I have seen at least four different ones. KLG ,Lodge,Magnetti Marrelli and Beru.
  #1009 (permalink)
Old 04-29-2009, 05:36 AM
Some spark plugs have a thing on the tip that is threaded and removable; it screws off and on. We have been led to believe that this is a resistor but in actuality it is a seed. That's right it is a spark plug seed! Some spark plugs have them and some don't. The ones that have them are female spark plugs and the ones that don't have them are male. The spark plug industry does not want you to know this but when you have used up a spark plug that has the removable tip (seed) you can plant the tip in a pot and a spark plug bush will grow from it. If you need a variety that has a hotter spark you just water them less. If you need them to be a colder spark, you water them more. I have been growing my own spark plugs for more then thirty years now. The bush that they grow on kinda looks like a pepper bush. It is the PH balance of the soil that gives them the different colors. If the soil is more alkaline the color will be yellow and if it is more acidic the color will be pink. A perfect neutral PH balance produces a white spark plug. Due to modern farming practices you don't see as many different colored spark plugs as you used to. I have experimented with different PH levels and even-though it does produce different colors, it does not seem to effect performance.
Chris
  #1010 (permalink)
Old 04-29-2009, 08:59 PM
Semper Gumby
Wiki Edits: 2
Pink plugs
It was LODGE I was thinking of - my wife found one while digging in her garden (old farm land) So, thinking it had been dyed by chemicals in the soil and not having ever heard of LODGE plugs, I did a bit of research. Yes they were pink. The insulator was sintered aluminum (or since they were British - "Aluminium"?) which was easy to work, could be extruded like tooth paste and became pink and hard when baked. Therefore I had to phrase the question carefully - I couldn't say "the porcelain was pink" as Lodge didn't use porcelain. I think Lodge made the plugs for Magnetti - but not sure. Over to you Mercmad63!
  #1011 (permalink)
Old 05-06-2009, 04:43 PM
I sure hope I didn't kill this thread with my smart *** answer to the spark plug question. I was just kidding guys!
  #1012 (permalink)
Old 05-06-2009, 09:34 PM
Semper Gumby
Wiki Edits: 2
spark plugs
Darn...
Now you tell me I wasted my time planting two rows of NGK platinums.....
  #1013 (permalink)
Old 05-15-2009, 11:54 PM
Well I guess I did kill this thread. It's been almost two weeks is anyone gonna post another question?
  #1014 (permalink)
Old 05-17-2009, 11:35 AM
I have no idea why, but it died off. I don't know about you but I was having a ball with this thread.
How about this one?
What year had the last Ford Roadster? (I mean REAL roadster, not some Escort or crap like that called a Roadster).
  #1015 (permalink)
Old 05-17-2009, 05:18 PM
Will I ever get it done?
Last journal entry: Hood
1966 t-bird sports roadster
But that was a 2 seating row car that was converted to a 1 row seating roadster with a fiberglass cover.
So it could be argued that the 57 t-bird was the last true roadster.
Am I close?
  #1016 (permalink)
Old 05-17-2009, 05:20 PM
Joe G's Avatar
1967 Cobra.?
As I understand it, a REAL roadster doesn't have side glass.
  #1017 (permalink)
Old 05-17-2009, 11:48 PM
Nope, a true "roadster" doesn't have side glass. I'll give you a hint, it was a "V8 Ford".
  #1018 (permalink)
Old 05-18-2009, 03:50 PM
Semper Gumby
Wiki Edits: 2
Trivia
Aw c'mon guys - this is a FUN thread! Let's not just let it die out. I've "won" more than my share on here and had the "winner's privilege" of having to come up with the next question to "stump the audience", so I'm not gonna respond this time (I can't think of another good question to pose right now anyway!) but this is a fun thread, so lets have at 'er, here!
  #1019 (permalink)
Old 05-18-2009, 04:01 PM
richard stewart 3rd's Avatar
Last journal entry: 351W rebuild
Hi,
1936 or 37 Ford
Rich
  #1020 (permalink)
Old 05-18-2009, 06:35 PM
Joe G's Avatar
1999 Panoz Roadster
Sure it wasn't made by Ford, but it was a production car that used late model Mustang running gear.
I don't know. I can't think of any 'true' roadsters built by Ford after '67.
humor, trivia
What Type of thread? fe428fairlane Hotrodders' Lounge 5 06-10-2002 03:49 AM
