Hi,
A climate sensor Rich |
This was in 1961. Climate was what ya done to get up a ladder.
yea my mistake it didn't come out till 62, but they had been working on it since the mid 50s, plus it was Cadillac not the whole gm family.
I give up. |
Don't want to hold up the thread, so,, here's the skinny.
The pad had grooves on it. The AC pad was in two pieces while the nonAC was a one piece pad. The joint of the AC pad was in one of the grooves so when installed,it appeared exactly like the nonAC pad. Now this may not apply to all cars, but has proven to be true to all examples I've seen from the Pontiac , Mich plant. No reason for this is evident as the whole pad has to come off to remove the dash panel and there is no reason to remove any of it to service the air conditioner. I'll try a new question in a different vein. In 1904 a American car company built a two cylinder opposed engined car. The car was known as "Old porcupine". What was the company and why the monniker? |
Knox motor car, Named old porcupine because of the cooling system that was a lot of "pins" coming out of the cylinders to dissipate heat. Joel
34Fords
Right you are. The engine was air cooled and had about 300 1/4" rods screwed into the cylinder jugs for cooling instead of fins. It was offered in single and two cylinder versions. Don't trust Wiki. It is only as accurate as the persons contributing. OK 34 , your on. |
Ok, Bone, Lets try this. What american made V-8 head would work on what 4 cylinder engine? Joel
Pontiac 389 (I assume 326 as well, or maybe they used the 326?) . But there are TWO that I know of, how about the "Sesco"?
Brian Pontiac Tempest motor. YES, that is a four cylinder to those who havn't seen one. Last edited by MARTINSR; 07-07-2009 at 11:47 AM. |
Brian, You are correct!, I had a '63 tempest convert. and it had a four just like the picture. Wish I still had it! Floor is yours. Joel
And it was a 389 that I was thinking about, I forgot about the little chopped SBC.
The gas Tank.
| Tags |
| humor, trivia |
| Recent Hotrodders' Lounge posts with photos |
| What Type of thread? | fe428fairlane | Hotrodders' Lounge | 5 | 06-10-2002 02:49 AM |
