The last time I saw a bracket with a big mounting hole like the top bracket has was on a Audi compressor bracket. It used a rubber insert that the mounting bolt went through for vibration purposes but I don't ever remember see a bumper mounted th at way. If that is what that big hole is for., then the top bracket would be for the newer car because the rubber insert would be used to correct a problem There is only three holes in that bracket and the two smaller ones are on a curved section that would fit against the body so the big one would have to be a bolt hole also and that hole looks bigger than a 1/2 " bumper bolt.
