Trobo 350 With 9" Long Pot Put Shaft Housing - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-26-2011, 07:34 PM
lconnell's Avatar
Dan & Shirley's 29 Ford
Trobo 350 With 9" Long Out Put Shaft Housing
Hey.. I bought a rebuild turbo 350 at a swap meet this past month in a box. When I got it home and out of the box, I noticed it had a longer tail shaft than the one in my 29 ford sedan. (Mine is a Tubo 350 C Short Housing). So now I will sell my new transmission. What make / models used the longer output housings?
Old 12-26-2011, 08:15 PM
BOBCRMAN@aol.com's Avatar
Various. Trucks, vans, station wagons
Old 12-27-2011, 01:55 AM
lconnell's Avatar
Long output housing
Yep! Thanks, that is what I thought.... Anyone need a truck turbo 350?
Old 12-27-2011, 03:06 AM
Wiki Edits: 85
Why not change the shaft and keep it for your vehicle? Isn't that why you bought it in the first place?
Old 12-27-2011, 04:53 AM
NOT a bolt on deal. Trans must be completely disassembled.
Old 12-27-2011, 11:01 AM
Wiki Edits: 85
The original post said:
When I read it, I assumed that he meant that he bought a disassembled transmission in a box. I did not read rebuild as rebuilt. Now that I have reread the entire post, I see where he meant rebuilt and not rebuild.
And changing the shaft in an assembled transmission is quite hard without disassembly.
Problem on the input housing and shaft assembly?? old yukon Transmission - Rearend 1 02-28-2011 07:36 PM
Short shaft on long shaft tranny sooper Transmission - Rearend 2 07-07-2010 04:14 PM
Short and long shaft TH350's.... and extra long too? 383ram Transmission - Rearend 11 02-27-2009 05:08 AM
Tail Shaft Housing...Long or Short??? lt1_performance Transmission - Rearend 4 07-11-2007 10:14 PM
Changing T350 short shaft to long shaft Jmark Transmission - Rearend 6 01-17-2004 04:22 PM
