trouble with 700r4 - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-09-2013, 10:25 AM
trouble with 700r4
hi everyone, new here and looking for any info. just put a new trans in my coupe 700r4 with a tci 2500 stall converter in it. my propblem is it shuts down when put in gear? cant figure it out ajusted the tv cable no help. any ideas ?
thanks barry.
Old 07-09-2013, 10:42 AM
jokerZ71's Avatar
Wrench Turner
Is the TC a lockup convertor?
Old 07-09-2013, 12:16 PM
not sure its been awhile i'll have to find my paper work on it. does it make a differance if its a lock up or not ? this trans is new to me should of stayed with a turbo 400 lol. thanks barry
Old 07-09-2013, 12:25 PM
jokerZ71's Avatar
Wrench Turner
It is designed for use with a lockup TC.Ppl do run w/o em tho.Not sure what they have to do to make it work rite tho.There is an electrical circuit that runs thru the brakelite switch & a solenoid for operation.I'm not sure that would cause your problem,but,it is possible.You should have a plug on you tranny for that & VSS if the trans is still in stock form.
Old 07-09-2013, 01:18 PM
Sounds like the sprag in the converrter is busted not allowing you to have any kind of slippage required for park or neutral
Old 07-09-2013, 01:27 PM
jokerZ71's Avatar
Wrench Turner
Those convertors can be tricky to put on.They have to drop twice I think.It's a common problem & once you start it up,it's too late.
Old 07-09-2013, 01:31 PM
jokerZ71's Avatar
Wrench Turner
Is the TC the same one you were running with the TH400?
Old 07-09-2013, 04:31 PM
no its not all the parts are for 700r4 still not sure on tc being lockup or not. this is in my brothers 29 ford behind a 350 trans is rebuilt stock with 2500 stall converter. i told him not to run it i dont like them but he is a dumb *** lol. just trying to help him out if i can. and i think his tranny guy is a shmuck. we get the duh im not sure why that happens oh great lol. just glad its not mine.
Old 07-09-2013, 04:44 PM
jokerZ71's Avatar
Wrench Turner
If the convertor wasn't fully seated,it's prolly toast already.Maybe he'll get lucky & it turn out to be somethin simpler.
Old 07-09-2013, 05:23 PM
yes i agree but you would think it would make noise when you start it? but it runs fine its like dumping the clutch on a stick at idle just shuts down its wierd.
Old 07-11-2013, 12:01 PM
hey joker new info
ok here is the latest lol. this trans was rebuilt 3 years ago stock new b&m lockup tc. this all sat in the cars frame WITH NO FLUID IN IT FOR 3 DAMN YEARS. OMG what a dumb ***. lol so im thinking something is stuck inside to keep tc locked up. with rear tires off ground its fine soon as you hit brakes it dies. what do you think. lol
Old 07-11-2013, 12:36 PM
If everything inside is new it shouldn't be a big deal it sitting without fluid. If the converter wasn't seated all the way in the trans you would have some problems getting the bellhousing mated to the block. It sounds more like the clutch pack is seized up to me.
Old 07-15-2013, 10:30 AM
That is not what I was talking about. There is a sprag in the converter, when is busts the converter no longer functions properly. If I'm reading your orginal questions correctly once place the vehicle in gear and try to apply the brakes rather than converter slipping or providing stall, it kills the motor rather than slipping. When the sprag busts it acts like it has a direct drive. The converter is seated all the way, the transmission as a whole would not be working and it would not move. It takes nothing to take out the front pump in a 700r4, it simply would not move in any drive range.
Old 07-15-2013, 10:55 AM
jokerZ71's Avatar
Wrench Turner
Sounds like somethin ain't rite in the tranny.The Rebuilder may have made a boo boo on assembly.It's prolly gonna need to come apart to figure it out I think.Most good Rebuilders will upgraade the pump,sprag,sunshell,etc to newer updated parts during a rebuild.All of those parts were weak links in the 700 & the ealier 4L60's.Sounds like a botched rebuild job,or, it simply be a bad convertor.Will it drive if you don't brake it,or,does it die as soon as you put it in gear?
Old 07-15-2013, 11:36 AM
jokerZ71's Avatar
Wrench Turner
Are the wires for the VSS & Lockup Solenoid hooked up?
92 GMC Sonoma shifting trouble 700r4 rbenz2001 Transmission - Rearend 1 03-29-2013 09:27 PM
700R4 trouble RobbieH Transmission - Rearend 6 03-23-2012 03:13 PM
700R4 trouble JCS 636 Transmission - Rearend 13 09-28-2009 08:43 AM
700R4 trouble shooting help Not A T 25 Transmission - Rearend 7 09-05-2007 09:59 AM
700R4 trouble kuhn-77 Transmission - Rearend 1 07-26-2006 02:49 PM
