Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Trouble bleeding brakes.
Old 02-28-2013, 06:56 PM
macrobert68's Avatar
macrobert68 macrobert68 is offline
Small Block
my trick to bleding brakes is open all cylinders at the same time watch your master cyl and keep it full .gravity will work every time .Also check those rear brakes if they are not snug it takes most of your pressure to spred the shoes resulting in a mushy pedal
good luck hope this helps
