Trouble Code - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-29-2005, 06:59 PM
jwash56's Avatar
Trouble Code
Hello
I have a 1993 Buick Roadmaster with a 350-5.7l TBI and it has been running roughly when hot for the past 2 weeks. I checked the EGR valve and the fuel system. Recently the service engine soon light has come on and i got trouble code 23. The code says "Inlet air temperature sensor signal showed an air temperature below -22? F after the engine has been running for 5 minutes. On Fleetwood the inlet air temperature signal shows a temperature below -20? F for 5 seconds at a speed less than 44 MPH." I took the IAT sensor out of the air cleaner assembly and tested it's resistance with a ohmmeter and it showed 2.12 when the engine was cold, 1.57 when the sensor was warm and .30 when it was hot. I used a hair dryer to change the temperatures on the sensor. Any help would be greatly appreciated.
Thanks in advance
John
Old 08-30-2005, 05:25 AM
New Member
Replace it with a new one, it it still does not work right look for a mouse that has been chewing on you wireing harness
Donald Stabnau
this is a saver.... GM build codes TooMany2count General Rodding Tech 24 11-23-2009 09:36 AM
BMW tranny code??? BlownBirdy Transmission - Rearend 4 03-03-2006 08:19 PM
Code has me Stumped 8.5" 10 Bolt Posi Ghetto Jet Transmission - Rearend 1 03-13-2004 03:50 PM
Paint code for Indy Beretta RT40Auto Body - Exterior 6 01-05-2004 07:19 PM
Error code while uploading dmorris1200 Hotrodders Site Suggestions and Help 2 07-28-2003 06:26 PM
