Trouble code p1870 95 Tahoe - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-15-2011, 05:24 PM
Hello every1. I got a problem with a 95 Tahoe w/129k miles.I got a p1870 code yesterday,and would like to narrow down what could be causing the problems I am having.Thanks for the help.
Old 04-15-2011, 05:38 PM
are you having a vary harsh 1-2 shift?
With GM's 4L80-E, this code has usually been the result of a cracked converter clutch piston in the valve body.
gm has a tsb on the topic for trucks built before 1999
Old 04-15-2011, 11:29 PM
Not always a hard shift.Sometimes it winds out,and others it kind of shifts hard.I have a 9 inch lift on it with 35 inch tires.It will sputter,piff,poofs,and acts like it is loosing power between 40-50mph,but anything above 50 mph it runs strong.It does this more or less between 2nd and 3rd.
P1870 95 Tahoe 4l60e vongoejr Transmission - Rearend 6 04-16-2011 06:36 PM
4l60e p1870 code mitchmc Transmission - Rearend 4 11-21-2008 03:21 AM
Another P1870 code thread ihateP1870 Transmission - Rearend 6 12-16-2007 05:32 PM
Trouble Code jwash56 Engine 1 08-30-2005 05:25 AM
