Trouble getting brake fluid to flow - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-24-2013, 09:38 AM
I've got a 1950 Jeepster with a new disc drum brake set up I'm trying to bleed. It has new lines, residual valves in the correct flow, wheel cylinders, and a new Speedway power brake and master cyclinder. I've bench bled the master cyclinder and am trying to vacuum bleed the lines. However, I don't seem to be getting much fluid throught the master cylinder. When I depress the pedal, there isn't much coming out of the master cylinder and no fluid at the wheel cyclinders. Is there something I'm missing to get the fluid into the lines so I can start to bleed them? Thanks for any help, Tom
Old 04-24-2013, 11:28 AM
richard stewart 3rd's Avatar
Last journal entry: 351W rebuild
Hi Tom
Whenever I change brake lines, wheel cylinders, calibers, or m.c. I open all the bleeders & let gravity do the work, then close each bleeder as it starts dripping,
when I've closed them all, I start the vacuum bleeding. Works for me.
Good luck,
Rich
Old 04-24-2013, 04:45 PM
RWENUTS's Avatar
What's your pedal ratio?
You might not have enough travel in the push rod.
Old 04-25-2013, 10:55 AM
I'm not sure about the ratio. However, the MC and pedal came as a kit from Speedway. The rod is adjustable and I have at least 5" of pedal travel. I opened the bleeders yesterday, but so far no fluid is visible. I'll try the vacuum pump again, and if no go, I'll go back to the pump and hold 2 person method. Thanks, Tom.
Old 04-25-2013, 11:18 AM
life is a temporary assignment
If you have drum's in the back,, Set them tight for now,, Then after your done bleeding them back them off,,, This is a trick that I find that works well,,, When you first starting to bleed a new system this is a great way to get it started,,
Old 04-25-2013, 07:02 PM
Banned
just a thought did you blow air thru the new lines to clean them? Maybe something in their !
Old 04-25-2013, 08:35 PM
I unhooked the rear line at the Master cyclinder and blew air through with the farthest rear brake bleeder open, and got nothing. The residual valve is in the correct in/out set/up and the proportioning valve is open to full flow. Now I'll unhook the line at the rear of the prop. valve and blow from the mc and then blow the line after the prop valve to see what's blocking. I may be on the right track. The mc is pushing fluid but the vacuum pump isn't pulling anything either front or rear. I think I'll forget the vacuum pump and try the pump and hold bleeding process once I get the line blockage figured out. Thanks again, Tom.
Old 04-25-2013, 09:13 PM
I think I would have done that from the begainning...I never use a vacuum pump to bleed brakes.... Pump and hold is the only way.. For me anyway..
Old 04-26-2013, 03:08 PM
ogre's Avatar
the 'Duracell Project'
i like jeepsters
i need pics
Old 04-28-2013, 12:53 PM
Problem solved. The rear brake line from the master cylinder to the residual valve was plugged. Who would have thought that a new line off the NAPA shelf would be plugged. Lesson learned: Blow out the lines before and after making any bends. Thanks for all the help, Tom
The Following User Says Thank You to T Evans For This Useful Post:
NEW INTERIORS (04-28-2013)
Old 04-28-2013, 02:22 PM
It happens...
700r4 fluid direction of flow JFPeters Transmission - Rearend 4 04-07-2011 10:48 PM
700R4 fluid flow pittbull7934 Transmission - Rearend 2 09-19-2009 01:49 PM
TH350 fluid flow in cooler Jmark Transmission - Rearend 2 04-27-2004 08:14 AM
TH-350 fluid flow Busted Knuckles Transmission - Rearend 3 01-07-2003 05:37 PM
How much brake fluid? Limey Simon Suspension - Brakes - Steering 2 10-30-2002 01:36 AM
