I have a steel '32 tudor that is getting a new repo windshield frame or at least I thought it was. The frame has the glass installed and a brand new gasket from Bob Drake around the outside. When I install the frame I get the window to close to about 1" from the actual place where it will be completely closed. It seems that the rubber gasket is preventing it from closing. At the top the gasket is making a proper fit, but along the sides, especially around the curved part is where I seem to be running into a problem with it trying to seat. The rubber seems to be curling under. Is there a trick to installing this type of windshield frame? The window will still open and close as it did when it was stock. The rubber is soft and pliable and not hard. The only adjustment is at the hinge part where it allows the window to move 1/8" to the right or the left, but not in or out. I wonder how Ford did it back in 1932? Any ideas as to how I can fix this problem.
