Trouble installing half quarters, need advice - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-23-2006, 04:15 PM
I have a 1971 Chevelle. I am putting on the lower half rear quarters. The car is in pretty decent shape, but I want to do it right and just not patch and bondo. I have put one quarter on, and am going to redo it, it is going to need to much bondo to look right. When I put the quarters on, should I overlap the metals. and if so, should I put the new metal behind or in front of the old metal? I tried to weld the metal with the ends butted together and it did not work out well. And if I do overlap the metal, should I tap in the welded area? or just grind it downn and use filler to cover it? And do I have to use fiberglass first over the welded joint? or can I use bondo only if the weld is pretty neat and doesn't need much? thanks for any info -Chris
Old 06-23-2006, 05:49 PM
Last journal entry: 99 soft tail standard I painted
Hi Chris,
I allways like to butt weld panels together.The trick with butt welding two panels,is to weld a little at a time,and let the metal cool to not get warpage.If you have a 2 foot weld to make,spot it once at on end,once at the other end,and once in the middle.Let those welds cool,and connect the dots,takeing care not to get the metal too hot.If thatdoesnt sound like your cup of tea,yo0u can lap weld them.To lap weld them,you will need a flange tool.You can get a flange tool at Northern Tool,or in almost any tool magazine,they aren to expencive.I like to think of lap welding as roofing a house.I flange the lower piece,and punch a hole about every 2 inches,then rosette weld the holes on each end,then the center,and connect the dots again.The flange tool usualy has a punch on the other side of the flang.I hope I helped,and if you need any pics,I could take some and mail them to you,or post them here.
Old 06-23-2006, 08:37 PM
302 Z28's Avatar
I'd also go with butt welds. One of our club members has his 34 Plymouth at a popular paint shop and we have been going by every Saturday morning to check on it. In the shop is a 68 RS/SS Camaro that I have been watching also. This Camaro was in pretty sad shape and needed 2 rear quarters and the panel below the trunk in addition to a total floor. The guys at the shop separated the quarter panels on the crown line at the top of the quarters, just cut it off with a high speed grinder. They then tacked the new quarter on with welds about every three to four inches. They allowed enough time to cool and when the day was done they had both quarters fully welded. Followed that with grinding away the excess weld and went over the entire new quarters with a 36 grit DA pad. If I had not seen the quarters put on that Camaro I would have not been able to tell, it was amazing.
Vince
Old 06-23-2006, 10:10 PM
Hey, thanks for the replys. I'm going to pick up a flange tool tommorow. I think I'm just going to try lap welding the body parts. The butt welding I did was really bad, and since I'm not a good welder ( using a small lincoln mig) and probably don't have the best welder for the job, I'm going to take the easy route so I don't screw it up anymore then I already did.
Old 06-23-2006, 10:50 PM
KFX, Are you using a MIG or Flux core? It is hard to butt weld with gasless wire, a MIG is a lot easier and a lot cleaner no matter which method you choose. If you lap weld you will find that it is easier to do without warping than butt welding and unless you are doing a really high quality resto lap welding should not hurt a thing. Be sure and seal the lap from behind so that moisture cannot get between the lapped edges where it can cause rust. As the others have already said take you time don't weld too much at once and give the metal time to cool between welds. This is one area where impatience will cause a lot of problems.
Old 06-24-2006, 06:38 PM
Hey Oldred, I'm using a lincol mig welder with flux cored wire, the welder seems a little hot, I have it turned all the way down and have the wire feed as low as it will go without locking up ( doesn't seem to be the best mig machine, borrowed it from a friend, it's the base line lincoln mig) it's gasless. I'm definetley going to try the lap welding, seems like it should be a lot easier
Old 06-24-2006, 06:52 PM
Ok you would do a lot better with a MIG (M-etal I-nert G-as) instead of that fluxcore welder if one is available, if possible use .023 solid wire with C/25 shielding gas and there will be a world of difference in how well it welds. If you have to use the flux core it can be done but it is more difficult and will require more grinding to clean up. I would use the lap method for sure in this case since it will be easier just make sure that both panels are super clean with no paint, rust, dirt or grease on them. (some primers and weld through coatings are ok)
Old 06-24-2006, 08:44 PM
I am with red, the flux core makes it pretty tough. Butt welding with flux core would be pretty taxing for anyone so don't feel bad.
Here is how I see the whole butt weld vs lap weld, what is the "Bestest" way for you? If you do a quality lap weld it will do the job and is not incorrect at all.
Evil laid it out nicely for you. One thing that people will make a mistake with is using the whole patch panel they buy. You don't always need the whole thing so don't use it unless it makes sense. If you can use the whole thing and weld it near a body line to add support that is fine. But if you can weld nearer the lower part of the quarter you may save yourself a lot of warping.
Where exactly is the rust and how big are the panels you using?
Old 06-24-2006, 09:18 PM
Be carefull, a flanging tool can sometimes warp the panel more than welding, it tends to straighten crowned areas. I like to butt weld whenever possible.
« wet bodo | Sick »
need advice/ tips on installing air bags in a 1952 chevy coupe with stock suspension Kuztmchev52 Suspension - Brakes - Steering 7 03-07-2006 11:52 AM
Advice on installing carrier dpjim2 Transmission - Rearend 4 02-18-2006 02:46 PM
Advice on installing gears and posi in 7.5 rear? Fantasyridesprez Transmission - Rearend 9 12-27-2005 07:42 PM
Installing powertrax trouble 66novaht Transmission - Rearend 1 02-26-2005 01:24 AM
Trouble Installing Oil Rings 57Chevyman Engine 4 04-10-2002 02:30 PM
