Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Trouble with my 1981 c10 6cly.
Old 08-22-2009, 05:40 PM
eloc431962's Avatar
eloc431962 eloc431962 is offline
Evil Wicked Mean And Nasty
Wiki Edits: 37
Are the cables hooked up right at the battery? You know check the cables make sure they are correct . red to hot black to ground or does it have two black or two red cables , Trace them you could be hooking the charger up wrong. When i bought my vette and was restoring it i didn't pay attention to the cables it had a red and a black took the battery out no concerns put it back later and smoked some stuff i had red to hot black to ground but after all the bull, i traced my so called hot cable and sure enough it was the ground and they had a black to the hot so i check when i don't know, JMO. Just trying to help. Cole
