Trouble removing TCI lower control arms. - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-07-2011, 10:46 AM
Im in the process of removing my front suspension in my hot rod and replacing the control arm bushings and shocks. I have everything out except for the lower control arms. I have the hardware off and their just sitting there on the shaft that runs through the cross member.
How in the heck do you get them off?? I never removed control arms and am kind of at a loss. Do you hammer out the metal shaft that runs through them?
Help...
Old 02-07-2011, 10:58 AM
slow4dr's Avatar
You are correct, you just need to tap the 5/8" shaft out. Then the arm will pull away from the crossmember.
-J
Old 02-07-2011, 11:38 AM
Irelands child's Avatar
As long as you have everything else off, pull that big ol' nut off (backside is best) and tap it out with a brass drift. The coil over shock assy. and sway bar, if equipped, need to come loose as well. If it's more then a couple years old, there may be some rust in there that needs to be soaked in penetrant then when reassembled, some anti seize slobbered on.
Dave W
Irelands child
Old 02-07-2011, 08:46 PM
Thank you guys..Car was built 7 years ago and driven over 18000 miles, so it probably seized up a bit. Ill let you know how it works out.
Old 02-11-2011, 06:11 PM
OMG this totally sucks. this is one of the hardest things i have ever done on a car, the bushings are seized to the shafts the shafts are rusted into the cross member. I got one arm off and the shaft flush with the front side of the cross member as of now, but had to call it a night. On top of all that my Copressor broke so I couldnt use my Air hammer...GRRRRRR!!!
LOWER CONTROL ARMS. PLEASE HELP Pro1972nova Suspension - Brakes - Steering 4 03-01-2012 09:19 PM
lower control arms runn141 Suspension - Brakes - Steering 5 05-02-2007 04:49 PM
Changing to lower control a arms for Must II Mooshaker Suspension - Brakes - Steering 2 02-02-2003 06:21 PM
Nova Lower Control Arms Pro1972nova Suspension - Brakes - Steering 1 12-15-2002 01:26 PM
rear lower control arms oldsnut Suspension - Brakes - Steering 3 12-15-2001 09:01 AM
