trouble shooting
Hey there guys.
I’m just wondering if I could get some help, heres the situation. I recently put a newer engine and transmission in my firebird. The engine I put in was a 305 with (what I’m told anyways a turbo 400 transmission). There were some problems with the carb so I reasently replaced the old quadrajet with a brand new edelbrock 650cfm and the intake manifold with a band new edelbrock manifold. This was my first time doing this kind of work. I followed the instructions with everything and hooked up all the vaccuum lines just like before but now the tranny doesn’t shift god at all. I was told to make sure the vacuum line was hooked up but I can’t find one on the transmission is it possible that there isn’t one? Because I don’t remember unhooking one. Thanks Mike:confused: |
You need to run a vac line to the Vac modulator on the trans. On a 400 it will stick out like a small can near the belhousing on the passenger side. If the trans is a 350, the modulator will be on the same side but back at the rear next to the tail shaft.
I jaked the car up today and looked for one and I can't for the life of me find where to hook up the vacuum line. I looked at the on intakemanifold and the vacuume line in that where you hook the tranny to was closed off. so i don't think it was hooked up before. And it shifed great before. :confused:
after more investigation I found out that I have a th 700 r4 there is no vaccuum modulator on the transmission. But I still have the same problem with shifting, it won't shift out of 1st . and it feels very sluggish untill the engine reaches 4000 rpm. anyone know why this might be?
thanks |
adjust the kick down cable
your kick down might be your problem.
The problem is that this thread is verrry old.. :sweat:
this thread is 2 years old. the 700r4 does not have a kick down cable. There is a TV cable. If the TV cable is not set properly the trans can go into "fail safe" mode... then the 700 tranny will shift late as if the throttle is WOT. I have closed this thread since it is 2 yrs old. thx :D |
| All times are GMT -6. The time now is 09:22 PM. |
