Trouble shooting help needed - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-13-2007, 04:47 PM
I have a s10 with an LT1 drive-train. I just pulled it out of winter storage. It ran fine last fall. Now it cuts out when I hit the gas. It sounds like its backfiring through the air box. My first thought was MAF, so I swapped that out with the one from a 94' caprice 9c1. no improvement. Any help is greatly appreciated.
thanks!
Old 04-13-2007, 04:55 PM
docvette's Avatar
Wiki Edits: 12
Doc here,
Drain and put in some fresh gas first..may be all that is wrong.
Doc
Aftermarket Solutions
Electronic & Electrical
Innovations
poncho62's Avatar
Wiki Edits: 5
Bad gas..........plugged injectors...............
Old 04-13-2007, 05:30 PM
bondo's Avatar
Ayuh,.........
I'd start with a Fresh tank of Gas,+ a New Fuel Filter.........
Old 04-13-2007, 05:39 PM
Henry Highrise's Avatar
Lost in the 60's
Wiki Edits: 4
Yep.... more than likely stale gas....next time you store a vehicle...put fuel stabilizer in it. Drain out all the gas that you can.......change the fuel filter....put fresh gas in it mixed with a bottle of fuel system and injector cleaner.
Old 04-13-2007, 05:54 PM
LT-1 have dist behind water pump and some time corrode tne dist cap also coil goes bad and causes arcing and missfire
Old 04-13-2007, 06:17 PM
Thanks! I'll drain it tonight. Much appreciated!
How trouble shoot elect. forewheel dr. JMEDLEY001 Transmission - Rearend 4 01-26-2007 08:56 AM
Double Trouble 67 Mustang To Muscle exiled1 Hotrodding Basics 5 10-28-2005 08:38 AM
spring perch no welding needed ??? Can drive 55 Transmission - Rearend 1 10-07-2005 07:36 PM
need help w/14 bolt ff posi id and trouble shooting Jason Transmission - Rearend 12 11-25-2003 04:09 PM
trouble shooting 86 monte Engine 6 01-27-2003 11:56 AM
