Trouble Starting - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-28-2010, 07:17 PM
Trouble Starting
My son bought a 74 International Scout II V8 std tranny. I'm not sure if it's a 345 or a 304 but whatever it is it doesn't want to start. When you crank it it will fire up for about 1 second and quit. We put a new coil on as the spark seemed a bit weak. That didn't help tho the spark was a lot stronger. Any idea what might be causing this engine to not start. I pulled the gas line to the carb and it is getting fuel. Would the starter carb's accelerator pump be the problem?
Also, a couple of times it backfired through to carb. I don't remember if that is a sign of too advanced or retarted and I don't remember which way to turn the distributor to correct. It's been 40 years since I did this stuff.
Old 03-28-2010, 07:38 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
304: Rotation is CW, so turn the dist. CCW to advance it.
Firing order is 1-8-4-3-6-5-7-2, drivers front is #1, drivers side odd numbered, pass. even. I recall something like using #8 to time it, but check this to be sure.
I'd say to check to see if there's a ballast resistor that has gone bad- IF the engine starts, but dies as soon as you let off the key.
I suspect both engines are the same.
Good luck.
Starting gas engine with starting fluid Bill Riese Engine 15 03-18-2011 11:13 AM
dual batteries for starting darom Electrical 25 01-14-2007 06:06 PM
Starting Problem Classic34 Electrical 2 12-31-2006 06:43 AM
Pontiac 350 trouble starting A-BodyFan Engine 9 11-06-2006 01:31 PM
hard starting impala65 Engine 2 11-17-2003 10:50 PM
