tdc
Pull the valve cover off of the drivers side. rotate the engine watching the intake valve open and then close. continue rotating untill the balancer is at the tdc mark... if you think you have the wrong timing tab or the balancer spun. Do the same thing but you will need a dial indicator in the plug hole... rotate untill the piston is at tdc...
Another way ( more accurate) is to us a piston stop. Remove all the spark plugs, rotate the engine by hand untill it contacts the stop, put a mark on the balancer. Rotate the engine by hand in the opposite direction untill it contacts the stop. Mark the balancer. Exactly half way between the 2 marks is your ture TDC. Then rotate the engine watching the intake valve open then close, continue untill you reach your new TDC mark.. Keith |
One problem...
I don't have a piston stop and getting the valve covers off and on again is a real chore. but, I'll try pulling the covers and see what I can do. Beggars can't be choosers... thanks for the reply. it is always appreciated. |
tdc
Well you will have to go out and buy a piston stop then....
You may be able to take the breather out and look through it at the intake rocker...If you have a hole in the front of the valve cover on that side... Keith |
Tdc
Old school method:
Tear a 3" by 3" piece of plastic bag. Stuff it with a plug of toilet tissue. Push it ito the number one plug hole. Turn the engine clockwise by hand until you hear a "poof" (you will hear it) You are now close enough to drop in the distributor with the rotor pointing to the number one hole. The drive tang on the distrib usually lines up with the rotor position. Use long flat blade screwdriver to line up oil pump drive wo distrib will drop in. Double check plug wire firing order. Be patient. Nettio |
Pull the Number one plug. Turn the motor by hand till you start to get compresssion. With just a little manual dexterity you can put one finger in the hole and turn the engine with a ratchet with the other hand. OK, when compression starts, stop and drop a foot long piece of wooden dowel (1/4" preffered) in the plug hole. Turn the motor on up till the dowel stops coming out of the hole. This will get you close enough to TDC to spear the distributor. At this point, your timing marks should be fairly close to TDC and timing can be set. If not, you have another problem that's needs to be addressed. Stock Chebbie balancers have been known to slip, throwing the timing marks off. The only real fix is to replace it.
If you have trouble turning the engine, loosen the rest of the plugs to relieve cylinder pressure
NOTE: DON'T EVER USE A POSITIVE STOP WITH THE VALVES STILL ACTUATING.
If you use a positive stop, pull the pushrods for the cylinder so the valves won't have any chance to hit the stop. 61bone gives good advice. One hand on ratchet/socket, the other index finger on the plug hole. On engines after 1986, the side timing marks will no longer match up, as the new marks were moved to behind the water pump in the 12:00 position. This was done because these engines had so many brackets on them, the side scale just wasn't visible. So, new marks at noon, timing light down from the top, behind the water pump. |
An easy way docvette told me to do, was use a slurpie straw in the cyl one spark plug hole and watch for the straw to move up and down, when it starts to move and it moves the oposite direction, you know you just passed TDC...
Then use whiteout to mark your balancer... Are you sure you aren't on TDC or were you forgetting about comp and exhaust strokes I did that about a month ago... Good luck... John |
I think you are forgetting that when you turn the engine over you will get air pushing out of the spark plug hole twice for each firing cycle. Once for when the plug fires and again when the burned gases are pushed out the exhaust valve. The reason your TDC was so far off is probably because you checked it on the exhaust stroke. You needed to turn the engine until you got pressure at the spark plug hole a second time.
with the exhaust valve open, you won't get any compression at the plug hole.
Doc here,
Number 1 cylinder, TDC, compression, Timing marks aligned, Both intake valves closed , no pressure on the lifters (not too much slack either..) If you can't co~ordinate these, you have timing chain/gear or balancer issues.. Drop the dizzy in, and watch the rotor, It will advance clockwise a bit, this is because the gear teeth are diagonal cut, It will go about a tower in a half in some cases..Note the amount of change and then withdraw the dizzy. Line the oil pump shaft up to that location with a large screw driver, and reset the dizzy, for number one plug tower, allowing for advancing as the gears seat.. The easy way to do this is make magic marker lines on the base of the dizzy, for exact #1 plug tower, and the difference of rotor movement as it seats..due to the cut of the gears..(I.E...#1 and the amount of distance BACK required to make it sit on #1 plug tower when bottomed out..) #1 plug tower in the stock location for SBC's is 5 to 7 O'clock, (depends on year, and obstructions) 7 is usually good. Direction of rotation is clockwise. The F.O. is 1 8 4 3 6 5 7 2.. Put on your hold down just tight enough to hold it but enough to forcibly move it by hand, and start it up..set your static and total timing.. Static 10 to 12 is a good starting point advance defeated and vacuum line plugged. Total around 34 to 36 is usual on a stocker with advance hooked back up.. Tighten down the hold down, set your idle for 650 Manual trans, 950 Automatic, and drive it .. hammer it on the freeway, If it pings or runs hotter than usual, retard it a few degrees..If it dogs, advance it..Try also lugging it up a steep hill highest gear as slow as it will pull, If it pings check the timing again. That's it. Doc
Aftermarket Solutions Electronic & Electrical Innovations |
Ok problem solved....and it only took most of the day.
The problem wasn't the timing at all...although I thought it was. what was happening : no matter how many times I aligned the dizzy with #1, it just wasn't firing clean. It ran like at out of balance washing machine...like it was either 180 degrees out or at least a tooth off. So I spent most of the day checking and rechecking the timing marks, actual TDC, etc. Then I called in some reinforcements...namely my buddy anthony. He helped me rebuild that engine and i figured a fresh brain and set of eyes may do some good. It did. We dropped the dizzy in at TDC once again and still wouldn't run right. checked for fire on #1. Checked cap, rotary button, coil, etc. All good. Pulled the rotary button of and BINGO! One of the leads from the pickup coil to the module was off but still just barely making contact. It would fire off the module, but it was doing so extremely erratically. I put a new end on the offending wire and reconnected it. Ran like a top. fired right up and was exactly where I wanted it. So, after over 8 hours of rewiring, pulling the valve covers off and checking TDC, replacing the plugs and wires,etc, etc, etc it all boiled down to one measly connection. But now all is well and the truck runs GREAT. Thanks again for all the help guys. I guess assuming that the dist. wasn't the problem anymore was my downfall. Note to self: always check the simple connections first. |
Look at it this way, you learned to troubleshoot it, and you had a great time with your friend helping.
How's the curving and vac advance working? Should be good. |
Oh, the truck has never ran so good. The new weights are perfect and the vac advance works like a new one.
I'm always happy when I learn how to diagnose a new problem, but yesterday really pushed my patience to the edge. But, problem solved and a new symptom is stored in the old memory banks for the next time. It just kills me that I can fix someone else's vehicle the first time every time but always seem to have problems with my own. Hopefully my misadventure will help the next guy who has this problem. I think I may tinker with the timing next week. I have a vette to race at the local drag strip soon. Should be a pretty even match...hell, I helped set it up. Thanks again for the help guys. |
| Kids and trouble | Kevin45 | Hotrodders' Lounge | 15 | 02-20-2006 04:27 PM |
| True TDC / using a piston stop | driveability | Engine | 6 | 01-07-2006 12:44 AM |
| TDC and timing chain | adrock430 | Engine | 4 | 03-04-2005 02:45 PM |
| TDC or 180 degrees off? | jerseyjeff | Engine | 2 | 11-05-2003 08:29 PM |
| c4 transmission trouble | Steve W | Transmission - Rearend | 2 | 11-04-2001 07:04 PM |
