Trouble when turning - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-01-2011, 12:27 AM
classic cougar
my cougar drives fine but catches and grabs when ever it turns, any ideas?
Old 02-01-2011, 12:41 AM
ericnova72's Avatar
More for Less Racer
It would help to know what year and any other info about the car that might be important, like type of steering, type of rear axle, posi or not, what modifications you have done, etc.
My crystal ball doesn't have enough info to see your car clearly.
Old 02-01-2011, 08:01 AM
Come on now Eric squint your eyes tighter!
Dave, we need more info. The biggest, have you done any work or changes on the car around when it started doing this.
Old 02-01-2011, 07:03 PM
classic cougar
I just bought the car, and aside from modded disk brakes in the front and a new air filter and valve covers, the car is mostly stock. its a 289 1967 mercury cougar. im new to this and i just wanted to pick everyones brain to check every possibilities. I would assume this problem is just from age but i wanted to see wat you guys think, thanks.
ps. i think it might be power steering and the pump is suposidly not the greatest, but it seems to only catch in the steering itself and has no problem with the energy needed to turn
Old 02-01-2011, 07:06 PM
LATECH's Avatar
Do you feel it in the steering wheel or does it feel like it is inthe back of the car.?
Old 02-01-2011, 07:09 PM
classic cougar
in the steering, as if the wheel is stuck then suddenly gives and dives when it turns
Old 02-01-2011, 07:16 PM
LATECH's Avatar
It sounds like a power assist problem. You should have the front suspension inspected for any parts that may be binding or damaged or bent and possibly getting stuck or catching on the car itself. If it turns out to be an assist problem, You will need to check the pressure out put of the pump.You will need to hook a 500 psi gauge into the pressure line side to do that.
A simple way that may work would be to put in some lucas power steering additive , it may alleviate the problem. If the fluid is real dirty looking you should flush it before attempting to do anything as that may fix the problem right there.
Old 02-01-2011, 07:18 PM
Could be air locked in the system.
Old 02-01-2011, 08:01 PM
1ownerT's Avatar
Home School Valedictorian
Last wiki edit: Health and safety in the shop or garage Last photo:
Wiki Edits: 4
Something else to consider is that the adjustment on the steering box could have been over tightened.
Old 02-01-2011, 08:16 PM
classic cougar
this problem happens the same way everytime the exact same way without fail, if that changes anything.
ill check those things out and see if they work...the gear box needs tweeking according to a mechanic, so that might be it
thanks guys
I'm turning into a WUSS! Dave57210 Off-Topic 4 11-23-2010 10:59 PM
Why the pop when turning the acetelene off first? Dirty Biker General Rodding Tech 21 09-28-2010 07:44 PM
Grease turning to oil? tblaze General Rodding Tech 2 10-15-2005 06:47 AM
turning a 350 and 400 into a 383 and 377 bullheimer Engine 8 05-17-2003 04:43 AM
Turning my 350 into a 383? malibu65ss Engine 9 08-28-2002 11:56 AM
