Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Troubles with SBC 350 rebuild
  #22 (permalink)
Old 10-21-2009, 01:32 PM
lg1969's Avatar
lg1969 lg1969 is offline
Google "Tunnel Ram 406"
Gun Laker, I the exact problem on my I was rebuilding my 307. It turn out the distributor housing did not sealed properly were the oil passes around to the lifter gallery. If was you I would replace the distributor. If that does not work, you have to pull the engine out. Put it on a engine stand, drop the oil pan, use a small can full of oil put it on the pickup then turn the pump the gutted distributor or distributor primer pump, with a hand drill and see where the oil is escaping. Hope this help you.
