Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Troubles with SBC 350 rebuild
  #23 (permalink)
Old 10-21-2009, 05:49 PM
Gun Laker Gun Laker is offline
I pulled the oil pan and the the pick up seemed a bit high. Some people thought that a high volume oil pump with a standard pan might be cause me some pick up issues. So I will put a standard volume and use some heavier oil before taking the next step. I will also spot weld the pick up and prevent any movement that may have occurred. I had 5w-30 oil in the engine so I will go up a few and retry. Thanks for the continued feedback!
