Troubleshooting my 4 link - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 02-26-2013, 06:10 PM
Last journal entry: gus`s 40
I am running a adjustable 4 link set up but am by far no expert on them. A buddy told me that the bottom two bars should run parallel to the ground and are the adjustments you square the rear end up with. The top bars should intersect the bottom ones with an imaginary extended lines 2/3 toward the front of the car, the top left is to set pinion angle and the top right is for pre-load. After I set it up that way it would launch hard and push the rear to the drivers side, then I moved the rearend to the pass side about an 1/2 inch and now it leaves straight but my panhard bar is above the axle
  #17 (permalink)
Old 02-26-2013, 10:49 PM
Originally Posted by AJThor View Post
"When I have had that type problem, it's usually worn Heims on the track bar, which is what that diagonal link is called, or the track bar is in a bind, which may be causing the bolts to come loose.
Another thing to check is if the rear end is square in the chassis, if it is not square, it will push to the side on launch."
The track bar is not in bind, it looks great. The bolts were comming loose so we just added some lock washers. The rear is square in the chassis (as far as our measuring goes). The bottom two links are all the way short. The tops are both different but ever so slightly. .691in passenger side, .673in drivers side.
Having the bars the same length does not mean the rear end is straight in the chassis. I have set up pro built cars that had the four link mounts as much as 1" different from side to side. I always set them up with a string and a square to get the rear end perfectly square in the chassis.
There should be lock nuts on all the suspension bolts.
I am not a big fan of track bars on street driven cars, I build all mine with a Watts link on the rear end. In my experience the rod ends on a track bar wear out in about 100 miles of street driving, enough that there is enough play to affect handling.
  #18 (permalink)
Old 02-27-2013, 05:15 PM
Thanks for replies guys. We will read that article and hopefully do a much recheck and square the rear end. I wont be visiting my parents for another week so it may be while before we reply. But we will!
A/C troubleshooting mitmaks General Rodding Tech 12 08-01-2011 08:48 PM
three-link, four-link, or truck-arm?? dave_letu Suspension - Brakes - Steering 22 06-16-2006 04:57 PM
Troubleshooting Rada Electrical 1 08-05-2005 04:54 PM
4 link vs. triangulated 4 link. rear suspension bentwings Suspension - Brakes - Steering 4 11-23-2002 01:44 PM
Parallel 4 link or Triangulated 4 link rear ? RonWood Suspension - Brakes - Steering 1 11-13-2002 08:25 AM
