Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - trubo 400 torque converter
Old 10-13-2008, 07:54 PM
Crosley's Avatar
Crosley Crosley is offline
Global Moderator
Wiki Edits: 1659
Originally Posted by 71haulnazz
I already put the torque converter in the powerglide and it fit and spun everything correctly??? Turn the torque convert byhand and the powerglide back yolk would turn no play.
perhaps you missed the part of my post about the powerglide has a smaller input shaft and is a coarse spline.
the vehicle does not move because the drive hub of the turbine inside the t-400 torque converter is at best waving at the small input shaft of the powerglide.
IF your powerglide had been converted to a 'turbo spline' input shaft ... then the t-400 converter turbine hub would be transfering power to the power glide transmission.
Pull the powerglide transmission out.. look at the input shaft of the powerglide.......then install the correct torque converter for the P-Glide transmission application.
