-   -   trubo 400 torque converter (http://www.hotrodders.com/forum/trubo-400-torque-converter-146549.html)
71haulnazz 10-13-2008 06:29 PM
I had a 71 chevlle with a straight 6 and swapped for the 350. I obviuosly couldnt use the torqu converter from the 6 cylinder as it is way too small for the flexplate on the 350. My question is that, I put the torque converter for the turbo 400 onto the stock powerglide and I have the tranny full of fluid and the car wont seem to move or the tranny even engage. The vacuum line that comes off the back of the powerglide fell off a few times during tuning. The vacuum line runs through the linkage. I do have some adjustments to make tto the linkage. But I am moving the linkage by hand under the car and the tranny still doesnt want to engage??? I have taken the tranny through all rpms and it still doesnt engage?? It was perfect pre engine swap?? Do I need a different torque converter?? I have a turbo 400 tranny but just didnt want to install due to my untrusting purchase of this 350(which runs like a champ by the way). What can I try???
Crosley 10-13-2008 06:39 PM
The torque converter from a t-400 and a power glide will not inter change.
A stock power glide has a smaller , coarse spline input shaft.
:cool:
71haulnazz 10-13-2008 06:48 PM
I already put the torque converter in the powerglide and it fit and spun everything correctly??? Turn the torque convert byhand and the powerglide back yolk would turn no play.
Crosley 10-13-2008 08:54 PM
perhaps you missed the part of my post about the powerglide has a smaller input shaft and is a coarse spline.
the vehicle does not move because the drive hub of the turbine inside the t-400 torque converter is at best waving at the small input shaft of the powerglide.
IF your powerglide had been converted to a 'turbo spline' input shaft ... then the t-400 converter turbine hub would be transfering power to the power glide transmission.
Pull the powerglide transmission out.. look at the input shaft of the powerglide.......then install the correct torque converter for the P-Glide transmission application.
:D
