Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - truc won't start
Old 09-09-2012, 10:35 PM
jessedenny47 jessedenny47 is offline
Try this intake
while the 10 sec. it is running take some either spray and spray along the ports of the intake this where the intake meet the heads. spray along there and if the engine speeds up or continues to run the intake gasket has a leak. also on throttle body injection if the air cleaner is not on the air/fuel mixture will become to lean to run after the engine fan blow the fuel away from the bowl. I hope this will help let me know if it does. ************* on here at jessedenny47
Last edited by 68NovaSS; 09-09-2012 at 11:00 PM. Reason: No email posting, see board guidelines
