truck - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-16-2006, 03:24 PM
truck
how do i hook up the ignition on a old style 350 in a 89 s10
Old 06-16-2006, 04:31 PM
docvette's Avatar
Wiki Edits: 12
Doc here,
When you say "Old Style" Do you mean points or HEI non~Computer (pre ~1980)?
HEI is simple, just run a 10 gauge fused 40 amp wire from the Ignition switch to the terminal marked "Batt" on the Cap..
The other terminal marked "Tach" will be an 18 gauge white wire to your tach or tach Buffer (on a stock tach.)
Points are a little more involved.
Doc
Aftermarket Solutions
Electronic & Electrical
Innovations
Old 06-17-2006, 10:16 AM
truck
thanx i am sure its not point but i will check and let you know
Old 06-22-2006, 09:07 PM
truck
i think it is points so can you help me on that please
Old 06-23-2006, 01:23 AM
docvette's Avatar
Wiki Edits: 12
Doc here,
Wire the "Hot in Run" wire from the ignition to a ballast resistor, Then ballast resistor to the + Side of the coil.
Wire the - side of the coil to the distributer.
Run a wire from the starter solenoid "I" or "R" terminal to the + side of the coil..This is your secondary ignition..
If you have a Tach, it goes to the - side of the coil..
Mount the coil on a good bonded ground and install a noise filter..
That should do it.
Doc
Innovations
What engine is in my truck? canine1566 Engine 9 10-26-2010 03:06 AM
94 chevy truck maybe dist./ignition problem,please help! bluesmanjesse Engine 14 11-19-2004 04:31 PM
1996 Chevy 1500 Truck 4.3 V-6 Juicer Engine 8 09-28-2004 07:06 AM
Repatriated Cubans get new truck ! Rodrunner Hotrodders' Lounge 11 02-06-2004 04:20 PM
66 ford truck swapping a 240 i6 out for small block chevy igotachevyor2 Engine 0 04-14-2002 04:19 PM
